04-13-2015, 09:10 AM
#41
Knowledge is king! No doubt, it would be awesome to shed a couple hundred pounds from the coupler area. For those that can handle it, the Anderson seems to be a nice option. Just know what you are getting.
Happy Camping. Spring is finally here!
04-13-2015, 03:59 PM
#42
I have no experience using the Anderson system, but I wonder about coupler wear with so much force on the back of the coupler.
If someone has 10,000 miles towing with one of these can you take a picture of the underside of the coupler?
Linc
2014 Rockwood Windjammer 3006WK
2014 Ram 1500
04-13-2015, 06:11 PM
#43
[QUOTE=missing_link;834497]I have no experience using the Anderson system, but I wonder about coupler wear with so much force on the back of the coupler.
Linc
2014 Ram 1500[/QUOT
Are you talking about the hitchball and coupler? With the Andersen setup, the ball and the trailer hitch move as one because it has a sleeve so there is no ball wear.
04-13-2015, 07:16 PM
#44
I'm wondering about the little finger that comes up behind the ball to lock the coupler on the ball. The coupler normally takes the load of towing in the steel cup. The Anderson hitch seems to transfer all of the load to the latch. Many of the latches I've looked at don't seem capable of dealing with that stress.
Linc
2014 Ram 1500
04-13-2015, 07:28 PM
#45
Blog: RVroadtripper.com
I towed more than 10000 and no problem. Traded up tp a 5er so I cant go back for pics. I will say that is something I checked every trip. Never saw any unusual wear and the coupler was judt fine.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
04-14-2015, 12:55 PM
#46
The Andersen website (from what I hear) lists a few specific types/brands of couplers that are not compatible.
04-14-2015, 02:44 PM
#47
I know I received at least one bulletin from them.
04-14-2015, 04:52 PM
#48
Yes, you are correct their are a few couplers whose design is not compatible. Here is the footnote off of the Andersen web site:
"NOTE: Currently the Atwood 88007, 88010, 88555 and 88600 couplers are not compatible with the Andersen WD Hitch (all other Atwood couplers are fine)."
Here's an example of the Atwood 88007, note the ball housing is different:
04-14-2015, 06:38 PM
#49
How did you receive a bulletin? Did you order direct? I got mine from Amazon about June of last year and have never received anything. Just curious.
2022 F250
2014 Rockwood Roo 233s
04-14-2015, 08:15 PM
#50
By mail
06-04-2015, 11:54 AM
#51
Well got my first trip using my Anderson hitch I don't know if my trailer would be considered long and heavy 30wrls v lite. 6000 lbs ,600 tongue weight. Anyway seemed to do better on the return than on the way to where I was going, I've got a couple of tweaks to do, need to move the ball down one hole for one. Other than that, very quiet and easy to hook up, didn't notice any unusual wear so far I'm pleased with it.
Think about things before you do them make life easier not harder.
06-04-2015, 12:00 PM
#52
Don't be afraid to crank down on the chains. Per Jason at Andersen, the actual number of threads showing is not the determining factor. Each set up is a little different. You have to find a sweet spot between too tight and just right. As you already know the closer to level across the board the better.
George Scott
2015 Salem Hemisphere Lite 272RLIS
2006 Heartland BH 3400/Summer Home
2021 Sabre 37FBT
06-04-2015, 12:43 PM
#53
Trying to figure out how to shorten one link without cutting.
06-04-2015, 01:17 PM
#54
I have my Andersen WDH listed in the Classified section of this board.
06-04-2015, 01:23 PM
#55
Connect to the plate using the SECOND link and leave the first dangling.
Just glad to get away
06-04-2015, 01:52 PM
#56
Move your brackets foward if you have the room. You could even put a stack of washers in front of the nut.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
06-04-2015, 04:50 PM
#57
50 pounds of hitch holding 15000 pounds together. That don't add up to me !! I been a machinist for 20 years everything has a breaking point. That being said I like it heavy and lots of steal. Just me not saying its bad or good.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
06-05-2015, 09:17 AM
#58
Never heard of one breaking yet. We'll see.
George Scott
2021 Sabre 37FBT
06-05-2015, 10:35 AM
#59
My AWDH didn't break, but the anchor shackle where the chain connects to the plate did somehow. It was most likely improper setup as I had the chains under the plate vs over and out of the way, coupled with the angle and steepness of the site I was coming out of. Andersen was great though. Sent me a new one even though I could've gotten one from the hardware store. Still love it.
2022 F250
06-05-2015, 10:59 AM
#60
Always thought they were undersized. I bent the washer into a cone shape.
Hensley Arrow
