Old 05-02-2014, 09:55 PM   #1
harvester
Send a message via MSN to harvester
Anderson no sway hitch.
I have used this twice on short trips and never going over 55 mph.But the roads that I was on were very windy with tight corners and the trailer (26) ft never broke loose from it's grip on the road.I will be taking a trip of 3000 to 4000 miles this summer up many mountain roads and winding valleys thru B C and Alberta.I will post how it went.
harvester is offline   Reply With Quote
Old 05-03-2014, 06:56 AM   #2
You should be fine. Pulled our Outback last year 7000 miles and no problems in the mountains or the flat lands.
DaveandSue is offline   Reply With Quote
Old 05-03-2014, 07:53 AM   #3
I have had an Andersen for two years now and it has been great. Previously had a Reese. I just bought a 33'-6" toyhauler and hauled it home from the dealer (70 miles) and it towed great. I am leaving in the morning for a 400 mile trip and this time I will have about 1200 lbs loaded in the back end behind the axles. This should give it a real test. If it handles this it should handle anything.
comfun1 is offline   Reply With Quote
Old 05-03-2014, 09:10 PM   #4
harvester
Anderson hitch
Thanks Dave and Sue for your imfo.It's really helpful to have someone with experience on using this hitch to pass on good information.It seem that negative remarks have come from people that have little knowledge on how it works.I found it very easy to hook up and level the trailer and truck.Being new with this hitch I appreciate any good tips .
Old 05-04-2014, 12:32 PM   #5
Dave and Sue, Comfun1, what is your TV?
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 05-04-2014, 12:49 PM   #6
HONDAMAN174's Avatar
Check the brackets where they mount to the frame. Mine "moved" on me and it was the last place I looked- had a bad wiggle. Sorry- they shifted/slid forwRd. Moved them back and re tightened all again.
Just glad to get away
Old 05-04-2014, 02:16 PM   #7
harvester
hitch
Hondaman174.I read in the manual that they would need to be tightened.I have a new kind of bracket where the bolt on top rests on the frame as does the bottom one and they tighten up when the unit is towed .the other way is to run a short weld along the bracket.Harvester
Old 05-12-2014, 11:33 AM   #8
thebrakeman's Avatar
Could all of you guys (who use the Anderson setup) include your TV max tow rating, and the approx. loaded weights of your trailer?
thebrakeman is offline   Reply With Quote
Old 05-12-2014, 12:17 PM   #9
My TV is rated at 9000- but if you look at the year before it's 10,000 no changes made. Running about 1k tongue and 8000 loaded
Old 05-12-2014, 02:41 PM   #10
harvester
anderson hitch
In reply to the Brakeman.My towing vehicle can handle 10 500 lbs and my 26 ft. Trailer weighs about 7 000 lbs.The hitch can handle up to 14 000 lbs,I hope this helps.
hitch, sway
