Old 09-18-2014, 09:25 AM   #31
thebrakeman's Avatar
Originally Posted by comfun1 View Post
I have had a Reese WDH and sway bar in the past and for my last two campers I have been using the Andersen. No way would I consider going back to the bars. I made two trips over the passes in the Rocky mountains last year and two more this year. I have towed about 13,000 miles total now on two different trailers using the Andersen. These trailers handle as well as a Cardinal 5th wheel that I used to have. My current trailer is 33'-6" long. I think the new technology is hard for a lot of people to accept. It is leaving the familiar and stepping into the unknown, not to mention gambling a few hundred dollars in the hopes it works.
What is your tow vehicle?
thebrakeman is offline   Reply With Quote
Old 09-18-2014, 09:30 AM   #32
Originally Posted by BigBaron View Post
Sounds like a plan! Post some pics, too. I've heard a lot about the squeaking and creaking of those things...
I used my 1000 lb Equal-I-zer for 2 season without the jackets, and then 2 seasons with:
1. I had zero decrease in stability, even though it's obvious that there is less friction force applied. I attribute this to the fact that the 2 forward points of sway control are still in effect.
2. I would say the amount of noise (which was previously ridiculous and embarrassing) is only about 25% of what it was without the jackets.
3. The jackets are a cinch to place on and off each time so you don't lose them.
4. In 2 seasons of use, I see no significant wear on the jackets. They seem to have found the right material which can resist the compressive load, but not wear from friction.
Old 09-18-2014, 09:34 AM   #33
Kaadk's Avatar
Originally Posted by madmaxmutt View Post
Well, I ordered an Andersen. (just realized I have been spelling it wrong
I don't think I have ever seen a product where the actual owners seem so happy with it. The Internet usually brings out those that dislike items.
Anyway, I am taking the leap of faith with this one. I will let you know what I think after I test it out.
Yes, please let us know. I'm not in the market for a new hitch, the old one only being a year and a season old, but based on what I've seen I'm quite tempted to take an Andersen for a test drive. That looks like it'd be a lot easier on/off than the current spring bars, chains, antisway bars, etc... I have. Lighter too. My current hitch is a pain to put on/off.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
Old 09-18-2014, 09:52 AM   #34
Originally Posted by offroad View Post
Yes they are on my trailer brackets, and no issues at all with the L-pins that hold the WD bars onto the brackets. They just slip on from the bottom and drop onto the L portion.
Factory did say however, that you need the new style L-pin that has the flip down spring loaded wire (snap L-pin). The older style L-pin that used cotter pins won't work with the bracket jackets.
We'll be camping again this weekend, and I'll upload some pics and also report on noise reduction and any noticeable effect on sway reduction.
You have it backwards:
-The jackets will not work with the NEW style pins.
-The jackets only work with the old-style pins, with the cotter pins.
-So far, I have not seen Equal-I-zer come out with a design revision to allow the jackets to be used with the new-style pins, which is surprising.
Old 09-18-2014, 09:58 AM   #35
I hope this works out well for you. But for goodness sake, please do the rest of us a favor, and take some measurements for yourself and the rest of us. Measure your front wheelwell height from the ground:
a. before attaching trailer to ball.
b. after attaching trailer, but before engaging the Andersen chains
c. after engaging the Andersen
If you don't do this, but simply report how light and quiet it is, you will not be helping everybody answer certain questions that are very important to us. Those of us who find it crucial to move all lost weight back onto the front wheels want some solid data to prove or disprove our concerns that this system is not up to the task.
Thanks!
Old 09-18-2014, 10:17 AM   #36
Thanks!
Wilco. I am pretty (I'll use the nice word) meticulous when it comes to these things. I will post details when I get ready to install the hitch and results afterwards.
It should be here on Tuesday
madmaxmutt is offline   Reply With Quote
Old 09-18-2014, 10:20 AM   #37
HONDAMAN174's Avatar
If you decide that the unit works for you, see about having the brackets welded to the frame. Sometimes they "walk".
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 09-18-2014, 10:22 AM   #38
Thanks,
My plan is to drill the set screw positions. Once I have tested it out on at least one short trip, I plan to weld the outside brackets as described in the manual's optional installation.
Old 09-18-2014, 10:57 AM   #39
offroad's Avatar
They must have new jackets now, as the one's the factory sent me fit my brackets with the new style snap L-pins perfectly. The part number they sent was 95-01-5150
I'll post some pictures this weekend.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 09-21-2014, 09:12 AM   #40
I used to tow a 27' toyhauler with an f150, now I tow a 33'-6" toyhauler with a GMC 2500.
comfun1 is offline   Reply With Quote
equal-i-zer
