Old 04-21-2015, 12:37 PM   #11
thebrakeman's Avatar
Search engine is your friend!
thebrakeman is offline   Reply With Quote
Old 04-21-2015, 07:01 PM   #12
Set up the Anderson hitch on my 14 Sierra then towed the 31 foot Windjammer to the Smokey's from Michigan. The best the TT ever towed even had to lock up the brakes once.
msroll is offline   Reply With Quote
Old 04-21-2015, 08:05 PM   #13
northstar1960's Avatar
Originally Posted by pdchristensen View Post
Any feedback or opinion on the Anderson weight distribution hitch technology? I like the light weight concept. Seems like a good product, just curious for others opinions.
It works great , no sway , no bonce and wd is ok i can raise my truck 1.5" with the andersen . not quite back to stock but if your not trying to make up for too small a tv you'll love it
northstar1960 is offline   Reply With Quote
Old 04-21-2015, 08:34 PM   #14
Originally Posted by Scotty View Post
Agree, your comments about the lighter TVs is exactly what I've been reading. So as you I'm not worried about the front end issue.
X2 on weight distribution..seems best under 900#. I am at 600+ with 4 threads. Puts about 200# to the steering axle
Very happy with mine. Over 12,000 miles last year, and atleast 25 hook/unhooks.
Henboy is offline   Reply With Quote
Old 04-22-2015, 07:41 PM   #15
it may not be a good as expected but handles 1100+ TW no issues , just did 600 miles today through Missouri & Kansas ,Rig handled great 2500 hd 6l gasser and even got 9.0 mpg pulling the 29xlr DW 7240 TW 1090 Avg 68 mph with a few periods of 75 . one finger driving all day .
Old 04-24-2015, 12:29 PM   #16
harvester
Send a message via MSN to harvester
harvester
I have used mine for two years now and it's perfect.
harvester is offline   Reply With Quote
Old 04-24-2015, 03:15 PM   #17
You should not be trying to raise the rear back up to stock. You should be trying to drop the front back down to stock. Raising the rear end back to stock would likely overload your front axle, so don't worry about that.
If you have any front measurements, that would be awesome!
Old 04-24-2015, 07:48 PM   #18
KDHfan's Avatar
Been considering switching for about a year now. I haven't pulled the trigger, however. Maybe I'm misreading posts about the Anderson Hitch... But doesn't it seem that the guys that are having no issues and saying "works great for me" seem to mostly all have a 3/4T and up?
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-24-2015, 09:33 PM   #19
dsjohns71's Avatar
Exactly... I'm the same way I would like some feed back of those that have it with the 1/2 ton truck and around 900 ish tongue weight. My trailer fully loaded would be 8600 lbs.. Seems like most that have it of at least post have the larger trucks..
dsjohns71 is offline   Reply With Quote
Old 04-24-2015, 09:46 PM   #20
HONDAMAN174's Avatar
It took me a while to get dialed in as the brackets kept sliding on the frame I believe because of my 950 TW. Once I added supports for the brackets, it was easier to drive as more weight was put back on the front axle. Probably because each time I hooked up something had changed on my set up. I am a happy puller now- but I also added sumo springs to the rear for extra support.
Just glad to get away
hitch, weight
