05-23-2011, 02:15 PM
So what is the ideal setup? I am pulling a 26 TBUD with a Nissan Titan. It pulls fine put the "wag" you describe is pretty bad at times especially with a crosswind. I understand there will be some but it has been pretty overwhelming a couple times.
05-23-2011, 02:42 PM
Moderator
to follow the fender measurements which are explained in most WDH instruction manuals. Of you can go the local quarry, or grain storage facility and see if they will weigh the each axle, with and without the trailer attached. Then you will see if the WDH needs adjustment or not.
Many truck stops have CAT scales, and the charges are minimum to weigh you rig. but will still need to weight the truck without the trailer to get your baseline.
Ideally, the weights should be obtained as your truck and trailer are camping ready.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 599 |
| 128 members and 471 guests |
| 2000XLifted, 4Jeeperz, 5Galvs, acadianbob, autorot8, bean, bear17, Bearcat55, bikendan, BlakeB, bob34787, bob7794, Borwick, brookside, bryndlwulf, Busman1947, buzzmonster, caper, Capsfloyd, Cascade Bob, cat1956, cdbus, Char_n_Kath, comfun1, condo, Cowracer, cstover, cyclepuck, DAISY BOYKIN, danred, dasimser, dec1952, deerslayer, dimurrrw, dnicekid, donn, Douglasdh62, Drmstx62, DSN46, dtolar, duchie, dunnnc, elind, flc, fordmantpw, forthefunofit, gator14, gbpacker, GeorgieGirl, gmurrell, Gquist, gsocamper, Hammertat, Happy Vibe, herk7769, hokiecampers, icebrew, iscotty123, isz, JamesR, Jeep4Two, JJones, jkinger, jmswms, JoeR, joess, Joker, jphillips1075, judy3972, kegoneill, LFugate, lmcleister, louincal, maggiek, micalo, Mr. Legato, MT28rk, mtl roofer, mtnguy, munty, NanaKaren, NancyTX, pandkm, Pharmofish, phuss, Pinesman, Piston, pixleys, Playtime III, plcrph2, PrairieBoy, prof_fate, pwrplay, Ragin Cajun, Redheaded blue tick, Rescue1, rickthelen, rjshiflet, rob and lisa, rschoono289, rstewart06, russpat, rwzahm, Sailfish Bret, sbond, SDENN4281, shineysideup, Skippkon, skippy31405, snowbrid, softwarejoe, Stagger, Stank Bait, Stinger, Tech Admin, texashatter, tgarner2000, thaithco, tmmar, TN_Jeeper, Triguy, vinman72, viper48, wakamicamper, william.migues, willy, wneise, wvfireboss |
| Most users ever online was 996, Yesterday at 11:04 AM. |
