Old 12-04-2013, 06:34 PM   #21
Fulltime family RVer
Originally Posted by OldCoot View Post
But to my feeble mind, the actual weight is needed regardless of the meaningless percentage. Being a little fictitious, what makes the difference if it is 10% or 30% as long as the actual weight is within the lawyer stickers?
How do you suggest someone estimate the pin weight for a brand new model to the market while they're researching what to buy?
ependydad is online now   Reply With Quote
Old 12-04-2013, 06:35 PM   #22
Herk! Thank you for being wrong! You blew my mind with being 8% lower!
Old 12-04-2013, 06:46 PM   #23
You seem to be missing the point.
You are right... it doesn't make a difference what the percent ratio is...
but if you know it... as Doug calculator can provide...
you use it as a tool to estimate what the loaded pin weight would be before purchasing.
2014 CC 34RLSA
2013 RAM 3500 Laramie CC SB 4x4 CTD
sidney is offline   Reply With Quote
Old 12-04-2013, 06:54 PM   #24
Herk7769's Avatar
That was bothering me all day. I went back and (wouldn't you know it) picked a different (and wrong) one to correct my numbers.
It is correct below now. Feel terrible.
I am coming down with CRS these days...
HAM CALLSIGN - KC3FFW
Old 12-04-2013, 07:06 PM   #25
Originally Posted by herk7769 View Post
OC,
What we are trying to do is to answer the age old question; "Can my truck pull this?" BEFORE they buy it.
By using the floorplan's dry weight and pin/tongue (Yes, I know meaningless), we think we can predict within a percent what the pin/tongue load will be for an camper at its GVWR.
For example using the attached brochure from 2010 (since it is there) and we look at a Flagstaff 8528RLWS with a dry weight of 6830 and a dry pin of 1187 we get a pin ratio of 17.4%
At its max GVWR of 9187, THAT MODEL of camper should have a pin fully loaded around 1600 pounds. If your existing truck (loaded for camping with family, gear, hitch, gas, etc.) does not have a REMAINING payload of 1600 pounds, that model/floorplan is too much for your truck.
So the calculator seems to be running fairly close with verified numbers (except for my mistake).
STILL, IMO, the best way is to use the "optimum" 5th wheel pin ratio (20%) times the GVWR and see if you can carry that. (12% for a TT)
Then you can play with loading to move the weight around some.
That make sense to try to predict with some degree of accuracy what the loaded pin weight will be, but whether it is 10% or 30% is of no consequence.
Old 12-04-2013, 07:28 PM   #26
Hmm...
should I use my power of invisibility for good or evil?
2014 CC 34RLSA
Old 12-04-2013, 07:46 PM   #27
AquaMan's Avatar
Oh come on Coot. To "predict with some degree of accuracy" and not use the figures handed to you from the factory? The whole calculation scenario is a "what if" from the start. If you already have a fifth and you're slightly intrigued about whether you are within limits or not, you take it to a scale. If you're shopping, the best method is to use calculations from given data, his calculator does this.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 12-04-2013, 08:00 PM   #28
Not what I said AquaMan, I agree with the calculations using the percentages, I just said it didn't make any difference whether the percentage was 10% or 30% as it is just a multiplier. If the dry wt % is 10% fine, use it, if it just happened to be 30%, use 30%. I'm just saying it doesn't necessarily have to be between normally accepted values between 15%-25%.
Also, if my weight was within the lawyer sticker wt and it turns out to be 30% instead of in the range of 15-25, it's no big deal.
Keep cool Timmy.
Old 12-04-2013, 08:10 PM   #29
OC, so you're agreeing with the premise of the calculator? I feel like we're trying too hard if we're in agreement...
Old 12-04-2013, 08:13 PM   #30
You're right- the actual percentage is inconsequential - but it then gives you a multiplier to use against either GVWR or against an estimated actual loaded weight to come up with a close to realistic loaded pin weight (which you can the decide to go with or against the truck's stickers).
On the "Advanced" calculator that I have, I show the percentage, but down lower, I do the math to show the possible/likely pin weight and even break it down for axle weights for those who want to know.
weight
