Old 08-06-2016, 08:58 PM   #11
If you are trying to say that propane is included in the published tongue weight (in your round about way) then of course it is relevant how they calculate it. I know that many people, including myself had at least a 100 lb difference between the published tongue weight and the actual tongue weight of new trailers.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
lbrjet is online now   Reply With Quote
Old 08-06-2016, 09:19 PM   #12
Usually Confused Member
emm-dee's Avatar
Originally Posted by Airdale View Post
Where is the propane weight located?
Propane must be figured as part of the trailer's UVW.
Published tongue weight is a mandatory requirement for the trailer manufacturer. How they figure it is not relevant as long as the figures satisfy NHTSA.
I'm not saying the mfgr doesn't have to publish the tongue weight, but where do they show it. It is nowhere on my trailer. The only info I've found is shown on the FR website. I don't think that would meet a specific gubment requirement. BTW, at delivery my weighed tongue weight, with battery and full dual propane tanks, came in less than the website published weight.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 08-06-2016, 10:58 PM   #13
Airdale's Avatar
Find and read the specs for the trailer. The tongue/hitch weight is published there. I've previously provided the regulation that shows how the tongue/hitch weight is used in the weight calculations for the trailer- FMVSS 571.110, Paragraph S9.3.2 - why dont you read it?
That's because the regulation describes a GVWR condition.
USN - RET
DOD - RET
SSA - RET
Airdale is offline   Reply With Quote
Old 08-06-2016, 11:36 PM   #14
emm-dee's Avatar
Find and read the specs for the trailer. The tongue/hitch weight is published there. I've previously provided the regulation that shows how the tongue/hitch weight is used in the weight calculations for the trailer- FMVSS .2 - why dont you read it?
The only specs I can find are the ones on the white and yellow stickers. The website lists what FR says is specifications, but those are in a single statement referring to tha specific model...not a specific unit.
The requirements spelled out in the FMVSS statements don't mean diddly squat to the owner if documentation complying with them is not provided. That reg says the sticker on the forward right passenger entry has to have the relevant values for water and hitch weight. Here's a picture of that required placard on my trailer. Can you find the hitch weight (as required per your referenced regulation)?
Old 08-06-2016, 11:38 PM   #15
CaptnJohn's Avatar
When I ordered our 1st tanks were supplied at the dealer. You chose the size and number. I went with two. 20# as running dry was not an option. Big Reese hitch and sway control was added. Don't recall ever seeing or hearing any numbers. The 1974 Plymoith Fury pulled it without any problem over thoussnds of miles over 4 years. Things have changed in the last 42 years. That 369 cu in motor and 727 transmission in that car probably matched or exceeded many 1/2 ton trucks of today.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 08-07-2016, 12:07 AM   #16
Airdale's Avatar
When you read the government regulations. Published means published.
Here is a FR reference with published hitch weights. Other regulations require that statement to be in the specs.
When one is researching government regulations all that are pertinent to the specific subject must be read to get the whole picture.
Evo Travel Trailers by Forest River RV
On edit: S9.3.8 The permanent RV trailer supplemental label must contain the following information in accordance with Figure 6:
(a) The statement “CAUTION: A full load of water equals XXX kg or XXX lbs of cargo @ 1 kg/L (8.3 lb/gal)” with appropriate values included.
USN - RET
DOD - RET
SSA - RET
Old 08-07-2016, 05:55 PM   #17
Too Tall's Avatar
I was pretty impressed when I am Weighed my tongue for the first time also my trailer was pretty much maxed out as far as gross weight but the tongue was carrying 380 pounds more than I thought it would be. However, I had it 2 -6 volt batteries and had a full potable water tank which is between the tongue and the front axle so I'm not surprised that I had more tongue weight but that was more than I expected.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 08-09-2016, 12:42 PM   #18
When weighing you want to know more than the total weight of the trailer.
Try to get a separate measurement on the front and rear axles, also left and right sides, if possible.
If you search this forum you should find specific advice and useful forms on best ways to weigh your rig.
I had a 600lb difference between front to rear axles and that is quite a lot. So to fix that I needed to get the trailer level while in tow mode. I ended up raising my hitch to raise the nose of the trailer. I've gone as far as I can with hitch adjustment and I'm pretty close to level now and will need to add air bags to raise it further. I have to return to the scales to see if raising it made a difference.
To check if yours is level just use a tape measure from bottom of frame rail to the ground to measure at the front and rear of the trailer.
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
Old 08-09-2016, 01:13 PM   #19
Oaklevel's Avatar
A few term changes. They do not call it dry weight any longer.. and UAW old dry weight? is typical weight
From a current Palomino Brochure
GVWR (Gross Vehicle Weight Rating) – is the maximum permissible weight of the unit when fully loaded. It includes all weights, inclusive of all fluids, cargo, optional equipment and accessories. For safety and product performance do NOT exceed the GVWR.
GAWR (Gross Axle Weight Rating) – is the maximum permissible weight, including cargo, fluids, optional equipment and accessories that can be safely supported by a combination of all axles.
UVW (Unloaded Vehicle Weight)* – is the typical weight of the unit as manufactured at the factory. It includes all weight at the unit’s axle(s) and tongue or pin and LP Gas. The UVW does not include cargo, fresh potable water, additional optional equipment or dealer installed accessories.
*Estimated Average based on standard build optional equipment.
CCC (Cargo Carrying Capacity) ** – is the amount of weight available for fresh potable water, cargo, additional optional equipment and accessories. CCC is equal to GVWR minus UVW. Available CCC should accommodate fresh potable water (8.3 lbs per gallon). Before filling the fresh water tank, empty the black and gray tanks to provide for more cargo capacity.
**Estimated Average based on standard build optional equipment.
Each Palomino RV is weighed at the manufacturing facility prior to shipping. A label identifying the unloaded vehicle weight of the actual unit and the cargo carrying capacity is applied to every Palomino RV prior to leaving our facilities.
The load capacity of your unit is designated by weight, not by volume, so you cannot necessarily use all available space when loading your unit.
****************** Does not mention weighing the tongue/ pin.................................
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 08-09-2016, 01:18 PM   #20
Oaklevel's Avatar
If you need to know how to weigh go to CAT Scale web site : https://catscale.com/how-to-weigh/ ....... scroll down for campers and motor homes
1966 Mustang GT
1986 Mustang SVO
weight
