Old 08-04-2016, 09:12 PM   #1
owlandfox's Avatar
Another Weight & Balance Thread
First post, so go easy.
Wife has 2013 Ford F150 SCREW, 3.5 Eco Boost, 5.5 bed. 18" tires. Not max tow. Payload sticker says 1401 lbs. Good Firestones, truck is at BSA camp, so I can't read them right now. GVWR for truck says 7200 lbs!
TT is a 2017 ROO, 23IKSS. GVWR for trailer 6628 lbs.
Blue Ox hitch with 750 lbs bars.
with wife, 2 grandsons, me and some stuff in the bed, probably 700 lbs. Tongue weight was listed at dealer as 550 lbs. Yes, it was empty. So we added our usual stuff (original camper was a popup) So, camp chairs, tool bag, those sorts of things. I'm guessing about 650 on the hitch.
Drove to the UP of Michigan, no real issues, except for a terrible headwind.
3200 miles later, I did notice the nose of the truck a little high and weight and balance training came into play. (22 years USN Aviation) I decided to purchase a hydraulic tongue scale.
Weighed trailer at hitch .... almost 700 lbs! Probably going to swap out bars to the 1000 lbs ones.
so question is. Do the manufacturers actually weigh campers before they put the sticker on, or is this a guideline? Are hitch weights usually that far off? Or, once again, are those "averages"?
As camper is new to me, grandma and I are working through the "take this, don't take that" and then where to place it. I've convinced her that weight and balance are important!
(BTW, I am weighing the rig soonest to get true numbers)
Great Forum, love the comraderie.
Scott/Kathy
Virginia Beach, VA
2013 Ford F150 SCREW, 3.5 Eco, 5.5
2017 Roo 23IKSS
owlandfox is offline   Reply With Quote
Old 08-04-2016, 09:23 PM   #2
Usually Confused Member
emm-dee's Avatar
My trailer was 300 pounds lighter than the FR stated weight. The tongue weight (via Sherline and CAT scale) was 90 pounds less. Unless you go to a cat scale all the numbers (except max gross weight) are just a WAG.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 08-04-2016, 09:34 PM   #3
Wobbles's Avatar
My understanding is that the stated tongue weight(naked) does not include things like propane bottle(s) and battery.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 08-04-2016, 11:10 PM   #4
Airdale's Avatar
The trailer manufacturer’s hitch weight is an official number used one time before the trailer is sold. For the trailer manufacturer the published hitch weight when added to the total GAWR MUST equal or exceed the GVWR.
Once you own a trailer all weights are your responsibility.
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 08-05-2016, 01:05 PM   #5
1. The hitch weight as listed on the camper is the number created when this camper was weighed at the factory.
2. Battery weighs 40 lbs or so.
3. WDH adds another 50 lbs.
4. Anything added to the camper in front of the axle will add weight also.
5. You should be fine if you don't load the truck to the max. Put more gear in the camper near the axles. Too much in front will increase tongue weight. Too much in back could cause tail wag.
6. FWIW....I pull the same camper with a 2013 Ram 1500 4x4 quad cab hemi. I'm close on payload but well under on tow capacity. Pulls well with no issues.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 08-05-2016, 01:20 PM   #6
CaptnJohn's Avatar
Over the last decade +/- full propane is included in factory guess....
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 08-05-2016, 01:34 PM   #7
emm-dee's Avatar
My tongue weight according to the Sherline scale was lighter than factory published number, even with battery and dual propane.
Old 08-05-2016, 01:49 PM   #8
Airdale's Avatar
You are correct. The regulation was enacted in early 2007 and currently reads like this... "If applicable, the weight of full propane tanks must be included in the RV's UVW and the weight of on-board potable water must be treated as cargo." That is a quote from FMVSS 571.110, Paragraph S9.3.2.
Old 08-06-2016, 09:11 AM   #9
UVW is not tongue weight. No regulation states that propane must be added to the published tongue weight.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-06-2016, 12:15 PM   #10
Airdale's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Where is the propane weight located?
Propane must be figured as part of the trailer's UVW.
Published tongue weight is a mandatory requirement for the trailer manufacturer. How they figure it is not relevant as long as the figures satisfy NHTSA.
weight
