Old 08-15-2015, 01:14 PM   #1
gashog's Avatar
Anti-rattle devises for 2014 Ram 2500 with OEM Class V hitch
With the design of the factory Class V receiver hitch, I can't find any anti-rattle devises that will fit. I believe I've looked at everything out on the internet and nothing I found will fit my setup. Has anyone with a RAM found a devise that will fit and work? With all the excessive slop/rattling my hitch and receiver is showing a lot of wear.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 08-15-2015, 09:22 PM   #2
KenHwy61's Avatar
I have 2.5 inch receiver that I reduce to 2 inch with a sleeve. My WDH does have a small amount of up and down movement while in the receiver but once the trailer is dropped on the tongue weight keeps it from moving. Mine doesn't show any unusual wear. Are you having a different sort of problem or it is related to a sloppy 2.5 to 2 inch reducer?
Aviator Wright-Flyer#1908
1996 Holiday Rambler
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 08-15-2015, 10:15 PM   #3
gashog's Avatar
My WDH has a 2 1/2" shank so I'm not using the reducer. The shank is real sloppy and shows quite a bit of wear also the corners of the receiver shows wear. While towing you don't hear any rattling, but with this sloppy fit it wearing on my receiver hitch and the WHD shank. A few times I left the hitch on during short CG stays and it bangs and rattle.
Old 08-15-2015, 10:23 PM   #4
gashog's Avatar
Since I can find any anti-rattle devices that will work on my setup, I decide to experiment this evening. I'm machining out some clamps. Will have a machined plate on top and one on the bottom. They will be squeezed together with bolts. Almost have the top piece done. May work, may not.
ID:	85840   Click image for larger version
Old 08-15-2015, 10:43 PM   #5
KenHwy61's Avatar
Interesting idea. I hope it works for you. I thought of trying some kind of shims initially, but the shank didn't seem to rattle that I noticed. I have a Curt brand hitch instead of the oem so maybe that makes a difference.
2012 Ram 2500HD CTD
Old 08-15-2015, 11:05 PM   #6
schrederman's Avatar
I wrapped mine with 1" wide electrical tape. Not permanent but stops most of it. I know I will have to do it again next year, but it's cheap and takes about 10 minutes of trial and error to get it snug. I make it too tight at first, and peel some off to make it fit snug, so I don't have a bunch of pieces... that doesn't work as well, and they ball up. I do the sleeve and the hitch, and it works better than I thought it would.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 08-16-2015, 11:42 AM   #7
KAS
I wedge shortened wooden shims into the gaps on the top and one side. Works great and they stay put until I remove the hitch.
KAS is offline   Reply With Quote
Old 08-16-2015, 01:18 PM   #8
gashog's Avatar
I actually tried shimming. Put a plastic one on the top. After 200 miles it was smashed all up. I have .100 gap and when towing there's had to be a lot of force moving that shank up and down in the receiver hitch.
Old 08-16-2015, 01:23 PM   #9
Rick_Geneseo's Avatar
Camping world has a u-bolt set up with a round bar set up that I used. Works great.
Rick_Geneseo is offline   Reply With Quote
Old 08-16-2015, 01:23 PM   #10
gashog's Avatar
On my experimental project the top piece is just about completed. Need to start on the bottom. I'm hoping this will prevent the shank from any movement.
ID:	85864   Click image for larger version
Old 08-16-2015, 01:24 PM   #11
KAS
I used wooden shims, broke them in half, inserted them as I inserted the hitch and pounded them in at the same time. They never moved. The only thing is that the hitch is in so tight that you may have to use a hammer to get it out.
Old 08-16-2015, 01:26 PM   #12
gashog's Avatar
I looked at those, but they just won't work on my truck. Not enough clearance between the hitch and bumper and on the bottom the tow chain bracket is in the way.
Old 08-16-2015, 01:32 PM   #13
tjm
Gorilla tape.
tjm is offline   Reply With Quote
Old 08-16-2015, 02:07 PM   #14
Maybe.
Hitch Clamp - Hitch Coupling Tightener
mike.t is offline   Reply With Quote
Old 08-16-2015, 03:30 PM   #15
FYI
Silent Towing
grayfox is offline   Reply With Quote
Old 08-16-2015, 03:44 PM   #16
FYI
One more for ya
http://www.amazon.com/Lets-Go-Aero-S.../dp/B00LB0OX2E
Old 08-17-2015, 10:17 AM   #17
Chuck.C's Avatar
Another possible choice
De-Rattler - NSA RV Products
2013 Coachmen Mirada 35DL
Chuck and Susan, RIP Toby and Gracie, the greatest dogs.
Chuck.C is offline   Reply With Quote
Old 08-17-2015, 10:38 AM   #18
f5moab's Avatar
Wrap it with Velcro (the soft side). I have used this to stop squeaks and rattles in many vehicles.
f5moab is offline   Reply With Quote
Old 08-17-2015, 05:08 PM   #19
gashog's Avatar
Originally Posted by mike.t View Post
From all that I've researched is missed this one. This is a perfect design for my RAM, they just need to come out with a 2 1/2" Class V model and I'll be in business. Maybe I need to scrap my experiment and make one of these.
2014, 500, hitch
