Old 02-19-2012, 09:55 AM   #11
camper_Lucy's Avatar
Get the LS, they do not operate anything like what is being posted here, the rear end will not kick out, they are not squirrelly, sorry guys in the old days yes but in 2012 no. The LS system will provide even power to both wheels and then detect traction loss of one wheel and divert power to the opposite wheel (one that still has traction). This is what prevents the kick out of the rear end, if you did not have LS and lose traction in the drive wheel the truck will slip sideways as there is nothing to compensate for the loss of traction. The system monitors, maintains,and compensates the the transfer of power between wheels. In campgrounds this will help you even in loose gravel towing up hills, plus in areas where we get snow this will help with general traction in conditions where you would consider using 4Wheel in you had it, but can delay the use.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 02-19-2012, 10:11 AM   #12
Originally Posted by KKapa View Post
Both trucks have the 3.55 gears. No difference there. It comes down to Leather, Step Bars, and Chrome wheels which I will enjoy multiple times per day vs LS which might eventually come in handy at some point. If It were a 2wd truck I would get the LS for sure. Being a 4x4 I am really thinking the benefits won't be noticed. Also, then truck is A 24mo lease, so If I'm not happy with my decision I only have to deal with it for 2 yrs.
4 wheel and Limited Slip are apples and oranges, 4 wheel will help you in conditions where the front wheels can slip, rain is not one of those conditions, actually using 4 wheel in the wrong conditions is more dangerous than driving in bad conditions without it. In addition it is primarily only going to help you in a north/south slip condition, what I mean is when the back wheels lose traction all together, the front wheels will pull you through.
LS works side to side in all conditions, most accidents will occur in wet "rain" and puddle conditions, LS helps detect and control wheel power loss in these conditions that are to dry for 4 wheel to be engaged safely. A lot of people think 4 wheel works like AWD and it dose not.
Pullrite 20.5K
2012 Sierra 365SAQ
Old 02-19-2012, 10:28 AM   #13
M109Rrider's Avatar
Your confusing limited slip with traction control. Ls works exactly the way crocus said. And to the OP, 3:55 is a horrible towing gear. IMO you should keep looking for a 3.92.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 02-19-2012, 10:48 AM   #14
M109Rider, i beg to differ. Traction control is also known as anti-slip regulation (ASR) by the engineers, is typically (but not necessarily - as on AWD) a secondary function of the anti-lock braking system (ABS) on production motor vehicles, designed to prevent loss of traction of driven road wheels. When invoked it therefore enhances driver control as throttle input applied is mis-matched to road surface conditions (due to varying factors) being unable to manage applied torque.
Intervention consists of one or more of the following:
Reduces or suppress spark sequence to one or more cylinders
Reduce fuel supply to one or more cylinders
Brake force applied at one or more wheels
Close the throttle, if the vehicle is fitted with drive by wire throttle
The above computer system works over top of the Limited Slip system to control and invoke it based on road conditions, we are discussing the value of limited Sip which is required to even have ARS on a vehicle, they just do not market it that way.
The limited sip on it's own will transfer power between wheels but will not modify driver controls. In the old days it was clutch driven and caused some drivers to get the feelings of the items listed above, today LS in electronic and reacts much quicker thus those condition feelings do not occur, and does not require ARS to be present on the vehicle.
Pullrite 20.5K
2012 Sierra 365SAQ
Old 02-19-2012, 10:56 AM   #15
KKapa, lets look at this a different way. Most experienced towers will tell you the best tow vehicle is a 2 wheel drive truck, they will also tell you LS in a 2 wheel drive is a high priority, you even stated that yourself. So consider this if would not purchase a 2 wheel truck without LS why would you consider purchasing a 4 wheel one with out it. 95 to 100% of the time you will be in 2 wheel drive when you are towing and in conditions where you can not engage the 4 wheel.
As for the rear end ratio I too think that the 3.55 is not a good selection for towing.
Pullrite 20.5K
2012 Sierra 365SAQ
Old 02-19-2012, 11:09 AM   #16
Kaytee1206's Avatar
Thank you for all the info. I should add that we will be pulling a Roo 25RS, which has a dry weight of 4841 and a loaded weight of 6502. We won't be pulling a 10,000+ TT, so a 3.55 should be fine. The truck we want can tow 8500 and we will be well within that. We also live in Michigan, and plan to mostly travel here until our kids get a little older. Our "mountains" are simply just hills to most people. We also won't be camping past October, so snow shouldn't be an issue. I probably should have mentioned all this in the original post.
Kaytee1206 is offline   Reply With Quote
Old 02-19-2012, 11:14 AM   #17
Dave_Monica's Avatar
All I can say is that people change their camper more often then their tow vehicle and your choice may limit you for the next camper.
Dave
Nevermind...I see that it's a 2 year lease.
Old 02-19-2012, 11:14 AM   #18
In that case, get the nicer truck and forget the LS.
Like you said, being a lease, you can get a different one later.
Old 02-19-2012, 11:16 AM   #19
Kaytee1206's Avatar
Dave
It's only a 24 month lease on the truck, we won't be buying a new camper in the next 2 years.
Old 02-19-2012, 12:27 PM   #20
M109Rrider's Avatar
Lucy, you are correct about how traction and stability controls work however the OP question was in regards to a limited slip differential vice an open differential on a new Dodge Ram. An lsd, posi, anti spin diff..... what ever you call it does one thing, applies equal torque to both wheels all the time but will allow some slip to compensate for different wheels speeds while turning.
Jason and Billie
