Old 02-18-2012, 06:46 PM   #1
Kaytee1206's Avatar
Anti-Slip (Limited Slip) Differential Vs. Standard Differential Ram 1500
Hey All,
Today we looked at two different 2012 Ram 1500 trucks for a tow vehicle.
Both have Hemi, 4x4, Class IV Hitch, Tow Package.
Truck A - Add Chrome wheels, leater, step bars
Truck B - Painted wheels, cloth, but has an Anti-Slip Differential
To me, the anti-slip is more of a performace, racing, deal.
I am curious, when it comes to towing, if there is prefrence in either direction?
I am leaning twoards truck A, just because it is a great value for the added options, but I am curious about the differential.
Thanks for your feedback.
Kaytee1206 is offline   Reply With Quote
Old 02-18-2012, 07:54 PM   #2
M109Rrider's Avatar
No real advantage to limited slip on a 4x4 IMO unless your racing or off roading.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 02-18-2012, 08:04 PM   #3
I would always go for the limited slip if available. But, an aftermarket unit is a lot better than the factory setup.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
Old 02-19-2012, 01:35 AM   #4
Just a member
kandl's Avatar
KKapa, the LS in the 9.25 Dodge axles has been around for many, many years. It works well in limited traction conditions. I suspect that "Truck B" has the 3.92 ratio which is what I'd be more interested in for towing. The LS is bonus but generally when towing a TT we tend to avoid those conditions that make a LS differential so useful.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 02-19-2012, 06:47 AM   #5
lindy's Avatar
KKapa a major point on the differentials for towing is WHAT IS THE GEAR RATIOS? Depending on how heavy a trl you're towing gear ratio is the main factor. The lower the gear ratio the better for heavy towing. If like kandl says the LS diff has the 3.92 towing gears that's the one you want, if the other trk has the 3.55 highway gears. Towing gears will give you about and extra 2000lbs towing over the highway gears.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 02-19-2012, 08:45 AM   #6
Pirate Todd and Wench
The limited slip is an option for a good reason. I've had to pull into slippery wet campsite in the mountains before and as it started to come to a stop, thank god I felt the "thud" of the posse ass, and front end locking up to get my but up the hill with 10,000 pounds behind me. Its a new truck, don't build it cheap!
-Todd and Sherri
-2006 F250 Super Duty King ranch Diesel
-2012 Windjammer 3008w
-Equilzer 1200lb hitch
mrtodds is offline   Reply With Quote
Old 02-19-2012, 09:08 AM   #7
acadianbob's Avatar
I would definitely get the LS. In tight quarters, like backing in, 4X4 can bind. The LS would give you more traction in 2WD. Also, LS is nice in low traction driving conditions when you aren't using your 4X4. And believe it or not, LS provides benefit when you are in 4X4 as well. Then you have 3 drive wheels instead of 2. That makes a substantial difference when the going is REALLY tough; like deep snow or mud.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 02-19-2012, 09:25 AM   #8
A limited slip rear can actually be dangerous in slippery conditions with an inexperienced driver, as the rear of the truck can 'kick out'. That is what the 4x4 is for.
As for needing it when positioning your camper, with the weight of the camper on the truck, I seriously doubt you would be doing much spinning.
I have had both, and the only time I really needed the limited silp was when I was out hunting and driving down forest roads, pushing snow with the hood of the truck!
Old 02-19-2012, 09:34 AM   #9
MtnGuy's Avatar
Instead of 1 wheel tracking and 1 spinning in slick conditions, a limited slip differential will apply power to both back wheels, so the back end can get quite squirrelly going down the road. My 2 wheel drive 1979 F150 was a challenge to drive on snow and ice, but the limited slip did pull me out of some stuck conditions. Even with the squirrelly driving in snow and ice, I still liked that LS in my '79 F150, and now have it in my 2006 F150 as well.
Old 02-19-2012, 09:52 AM   #10
Kaytee1206's Avatar
Both trucks have the 3.55 gears. No difference there. It comes down to Leather, Step Bars, and Chrome wheels which I will enjoy multiple times per day vs LS which might eventually come in handy at some point. If It were a 2wd truck I would get the LS for sure. Being a 4x4 I am really thinking the benefits won't be noticed. Also, then truck is A 24mo lease, so If I'm not happy with my decision I only have to deal with it for 2 yrs.
2013 Rockwood Roo 25RS
