Old 08-18-2013, 05:05 PM   #1
Anti sway question
How tight should those puppies be? The first camper that I used this set up on I was on the 2-3rd link and sometime that was hard to get to snap into place. Thanks to places like this and a tech on my PDI I learned to hitch it and then take the weight off, makes it much easier. Told the tech that if they were to be that tight, that I had prolly never really used it before. He took it to the 5th link. Now here's what happened. The retention clips (see attached) are now bent. From the extra pressure and today after coming home from camping I unhooked, we unpacked and cleaned nd then hooked back up and took to storage. Got there and one of the pins was MIA and the chain had been dragging. It's (the camper is going back to CW this week for the first run of its broke already fixes. Ought need to hook up the sway control. Maybe. Hahaha. I'll just put a bolt or something thru it.
Thoughts? TIA.
ID:	38082   Click image for larger version
Just traded our first 2004 Starcraft 185SB our new 2013 Wildwood 291FB XL.
Spence, Brandi, Abby, Olivia and Boone-dog.
Spence is offline   Reply With Quote
Old 08-18-2013, 05:12 PM   #2
And no, I don't have model or pic info. That stuff is 11 miles down the road
Old 08-18-2013, 05:18 PM   #3
Brother Les's Avatar
Thoughts? TIA.
That is not for the 'sway bar' (sway bar helps keep unit from going side to side down the road). That is for the lift bars for lifting up the back of the truck and the front of the camper. You do need some heavy pressure on the chains, but the pins should never bend like that. There is a video on here somewhere on how to set up your truck hitch. I think that your 'ball' may need to be raised higher (I may be wrong on which way) and that will make it where you do not have to 'drop' so many links and have so much pressure on the lift bars. There are also 'pins' that are more heavy duty, but do not go that route right now, you have some adjustments that need to be done to your ball and hitch. my old camper I dropped 2 links, my new on I drop 3, to me 5 links dropped is a red flag of being unsafe.
Brother Les
Old 08-18-2013, 05:22 PM   #4
Found it. It's a camco elite weight distributing hitch.
Old 08-18-2013, 08:48 PM   #5
Thanks les. I realized I was calling it the wrong thing after some you tubing. I might try raising the ball. I'm not sure how high is too high but I was close to the top end if the jack today. I must have unhooked/unhooked my old camper 30+ times in the year I had it. Never had it that tight nd never had an issue other then hard to connect b/c of too much trailer drop. I'll have to look up some set up videos. The tech at CW did move it but maybe not far enough. Thanks les
Old 08-18-2013, 08:50 PM   #6
And I do have up get new pins. One is bent and the other prolly shot out of the set up like a bullet. Ha
Old 08-18-2013, 09:19 PM   #7
With proper setup the pins have (NO) pressure on them. They can be inserted or removed by lifting to clear the 90% bend of the pin. You are off on your setup. Pics. would help. Youroo!!
Old 08-19-2013, 05:42 PM   #8
Pics you say? Okie dokie. It's on the road so I'm pointed a little downhill. But you get the idea.
ID:	38163   Click image for larger version
ID:	38164   Click image for larger version
Old 08-19-2013, 05:46 PM   #9
Missing Link
cyclepuck's Avatar
Ball height does need to come up. Trailer should be close to level.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 08-19-2013, 06:40 PM   #10
Garrette's Avatar
Yes, the trailer and truck needs to be level. Looks like the truck is still down in the rear. The WD hitch is not setup properly.
Garrette is offline   Reply With Quote
