07-21-2016, 11:27 PM
Any Dodge owners out there?
I want to ask Dodge Hemi owners if this will pull in flat to hilly terrain a 6,000# Roo? I have a 183 now but may get something a bit heavier in the future.
Maybe 3 adults in the cab. Specifically worried about 3.55 ratio...
Looking at getting this unit...
2007 Dodge Ram 1500 SLT 4WD / HEMI 120,000 miles
QUAD CAB POWERED BY 5.7L HEMI ---4WD---
Axle ratio: 3.55
Any Dodge owners out there that can vouch for this vehicle?
2014 Shamrock 183
07-22-2016, 12:38 AM
I just pulled a Grey Wolf 19rr toy hauler loaded about 5800 lbs. on a 1,600 mile trip with a 2004 dodge ram 1500 single cab 2 wheel drive and it did better than I thought it would. It has the 3.92 in it. It was just me and my wife and maybe 100 lbs. in the bed of the truck. I dont know if this helps but good luck.
Scott
07-22-2016, 07:03 AM
Before I got the 2500 I have now I towed a Surveyor that weighed 5800 lbs with a Quad cab 1500 HEMI with 3.92 gears, BUT it had 20" tires so that put it about equal to the 3.55 gearing.
It did ok, but was kind soft. Then I got a real deal on the one I have now so I upped.
Gotta go campin!
07-22-2016, 07:17 AM
I have a 2015 RAM Quad Cab ( not a Dodge ) Laramie 4X4. It has 4 corner air suspension, 3:92 posi rear end, Hemi, 8 speed tranny. Once a year my RAM, not a Dodge, tows my 28RKX Wildcat MAXX (7,600lbs empty) round trip from Iowa to Seattle and back. This trip incorporate all types of terrain, desert, mountains, and everything in between. My Ram handles the Wildcat great, going up all the inclines and going down the other side. I know I'm on the edge for hauling capacity and went with the 1500 as it's my only vehicle and it's just what I wanted for a daily driver when not towing. We also use a Blue Ox Sway Pro WDH. Hope this helps at least a little.
PS- I towed this trailer once from Seattle to iowa with my 2011 Ram Quad Cab Hemi with 3:55 rear end. The Hemi did just fine even in the mountains with the 3:55, however, the coil rear suspension was 'taxed". Rear air bags would , IMHO, be needed to safely tow a 6000lb trailer with your truck.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
07-22-2016, 07:33 AM
My TT comes in around 5k. My 2016 hemi 5.7 pulls it just fine. Differential is 3.2 or so.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
07-22-2016, 07:52 AM
2005 Dodge Ram 1500 with 5.7 Hemi, Quad cab, 4WD, 3.55 gears.
Pulls our 2016 27RR at about 7,600# just fine. A little over weight per the paperwork but getting about 10 mpg when averaging 60-64 mph.
I don't think I would want to use this in the mountains but for the Midwest has been fine so far.
07-22-2016, 12:17 PM
Ram Tough
Axle ratio: 3.55
I have a 2014 Ram Laramie Crew Cab with the 5.7. I pull a 23 SS Roo. You can forget cruise control unless you are on completely flat land. I get 8-9, maybe 10 miles to the gallon if I am lucky. I have the 3.21 rear ratio.
As for hills, it chugs up the hills but sends RPMs up to 3000 and has to work to do so.
Hope this helps.
07-22-2016, 12:41 PM
We had a 2014 1500 Limited with the air ride and we used it to pull the Flagstaff 831BHDS later found out that it weights in at 8700#. Truck did Just fine, only upgraded the TV because we wanted a large toy hauler 5er, but have decided to wait. As always be safe and kind to one another.
07-22-2016, 12:57 PM
I pull a 34 ft windjammer with my 2015 RAM 1500. 392 ratio rated at 10,150 lbs. Trailer is about 8500 loaded and I have no problems pulling it. Howevwr, the gas mileage sucks! If I get 9 mpg, I'm doing good.
07-22-2016, 02:51 PM
I think that MPG is about average...
2014 Shamrock 183
07-22-2016, 03:05 PM
I have a 2014 ram 1500 crew cab 4x4. I just pulled a 36 foot long Hemisphere that when empty from the factory weighed in at 7700 lbs. I didn't get a chance to officially weigh it inbefore the start of the trip. I am speculating that with the Gear in the TT and the family in the truck I am right around 9000lbs. Which is right around my trucks max. From VA to new Hampshire I managed to keep an average MPG of 9.2. That is on the first half of the trip so a lot of mountain climbing. I also don't think I ever used more than 3/4 throttle. I was a little worried if the truck would have any problems with this trip. I don't think i will ever feel the need to doubt or question this trucks ability again. I am very interested in seeing what the return trip averages.
07-22-2016, 03:07 PM
2013 Ram quad cab 4wd hemi pulling early 2015 Shamrock 23IKSS. Perfect setup for me. Plenty of power and brake for this camper. Average 10 mpg towing at speeds not normally over 62 mph. Disclaimer....we live in Indiana, a state not known for its mountain ranges.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
07-22-2016, 03:10 PM
07-23-2016, 02:38 AM
We pull a 12,000 lb 5th wheel with our 2012 RAM 2500 Hemi 6speed. We have the 4:11 rear end and am told that makes a big difference. It has done very well on several cross country trips in all kinds of terrain. 60K miles on truck with out any non-routine maintenance required.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
07-23-2016, 06:49 AM
We tow with a Dodge Durango R/T that has a Hemi on it. I haven't weighed the trailer loaded but I'm guessing is about 6,000 loaded. We have no problems with it here at the East Coast.
07-26-2016, 09:17 AM
Should be good to go
Axle ratio: 3.55
I have a 2011 Mega Cab 2500, 6.5 foot bed with the 5.7 Hemi. The truck weighs 6300lbs by itself and our trailer loaded is around 6000lbs (Roo 25RS) and it does fine. I weighed on a trip last year with a typical load for the 4 of us and we came in around 13,200lbs. It has to work some on hills but cruise manages the speed on interstates maintaining between 60-65mph and around 8.5mpg. Depending on percent / duration of climb it will hit 4k RPMs but that is just part of the process with a gas motor. I have the 3.92 ratio. We've put a little over 10k miles in towing over the last couple of years with very little flat terrain in our region or anywhere we've gone to and the only time I've been concerned was in the Big Horn Mountains in Wyoming. We were loaded way more than normal, closer to 14k lbs and the climbing was intense. The engine repeatedly pushed over 5k and maintained around 35mph. There was no need to go any faster than that so the only real concern was trying to keep the trans temp in the 230s. Mileage was comical at 3.7 for that stretch. One thing to note is I have towed a buddy's heavier / longer trailer and it was much less work than mine. So there is an X factor depending on the aerodynamics / wheel & tire setup of the trailer being towed. Hope this helps.
TV - 2007 Tundra Dbl Cab
2014 Rockwood Roo 25RS
Nights camped 2014-27, 2015-28, 2016-31
Nights camped 2017-16, 2018-6, 2019-10
07-26-2016, 09:57 AM
RAM truck owners...
thanks for that specific info Admiral Roo
I let that used 2007 Dodge hemi pass me by... I am looking at getting maybe a '09-'12 now as I see some RAM 1500 5.7 with well under 100K... some even have the larger gas tanks... although the 4.7 engine comes up for sale 10X more then the 5.7 engine...
I figure the short box, 4 doors, 3.92 or 4.10 gears and a 5.7 should do me just fine... Must I stay away from 3.55 gears altogether? ... also...
looks like many Canadian market used RAMs show up at dealer lots... Is there any reason to stay away from those?
now to find one that I can afford... my '01 van TV has an economically unsolvable intermittent electrical issue that kills the engine, so I will get nothing but junkyard price for it... I will be looking going into September as I hope there will be some trade-ins this time of year...
2014 Shamrock 183
07-26-2016, 10:28 AM
Your welcome for the info. Not familiar with the canadian trucks. Good luck on the hunt, I'm sure you'll find something that fits the bill eventually.
07-26-2016, 11:16 AM
What do you mean buy a ram not a dodge ....... isn't that like calling a chevy silverado a silverado not a chevy
07-27-2016, 12:28 AM
We bought a 2008 Aspen 4wd with the 5.7, 3:92 gears and the tow package. For some reason this was much less then a similar year and milage pickup, and much nicer inside. The 05-09 Durango and Aspen was body on frame and almost the same as the 1500 pickup, many shared parts. We paid $10,500 for one with 140,000 miles 2 years ago from a dealer, and it had every option. I have seen more similar deals since, I would maybe look for a 2009 as there was a bit more power with the variable valve timing my 2008 does not have. I do have the cylinder deactivation which works well day to day but it is disabled by the tow/haul button.
PS mine was from Canada and I don't think it changed anything except I needed a police VIN inspection when licensing it in Montana.
