Old 04-25-2016, 09:55 PM   #1
Any down side to an E1 (10-ply) rated tire on a 1500?
I need new shoes for the 1500. We've had good luck over the years with Discount, so I went shopping on their site.
Unfortunately, in my OEM size, all the tires have a load rating of SL or XL, and since I'm towing the new TT I thought I should maybe bump it up.
Then in looking at their 'Equivalent tire sizes' (or whatever it was) section I found the Goodyear Wrangler SR-A that has an E1 load rating. Wowsers. 10-ply equivalent. And priced in line with SL and XL tires, to boot. $177 online, but the shop quoted me $165 (plus tax, plus m&b, plus disposal)
I'm a little worried that they're going to be stiff, especially unloaded and at high pressure, but other then towing I pretty much only use the truck for my .75 mile RT, 25 mph, daily commute.
Other than this E1 and the SL/XLs, the only other option was BFG All Terrain's with a D1 rating. Now, I had BFG ATs on a 4x4 and loved them, but this truck is 4x2 and doesn't need off-road tires. And they're more expensive at @ $230.
What do the experts think?
Oh, and reviews are all over the map. One says best ever pulling a boat up the ramp, and another says not the best in wet weather. Go figure. Seem to be popular tires with folks towing with a 2500.
Family of five camping in a Spankin' new
Grey Wolf 26DBH LTD pushing a
'03 Dodge Ram 1500 via
10k/1k HaulMaster WDH stopped by a
Prodigy P2 brake controller
DadOfTwo is offline   Reply With Quote
Old 04-26-2016, 05:01 AM   #2
10 ply tires are all I ever run even on half ton trucks. They will ride a little more stiff but not bad.
Crambo is offline   Reply With Quote
Old 04-26-2016, 05:50 AM   #3
I just took the leap of faith a few weeks ago. I expected worse mileage due to added weight. I'm actually getting a little better mileage. I expected a harsher ride, and, while noticeable, it isn't bad.
I did notice stability improvement when towing.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
tragusa3 is offline   Reply With Quote
Old 04-26-2016, 07:23 AM   #4
Wanna Be Camper
SaskCampers's Avatar
Don't forget, it is not the tire that carries the weight. It is the air so you need to run more air pressure to get any benefit of the LRE tires. Also 1/2 ton rims may not be rated for the increased pressure and you would for sure need to run high pressure valve stems possibly even having to change your TPMS sensors depending on how they are made if you need to exceed 50PSI. Michelin, TOYO and some others have a chart on their sites that shows what various pressures in specific range tires will give you for load carrying capacity.
Here is a link to Toyo's. Page 22 is where the LT tire chart starts.
http://www.toyotires.ca/sites/defaul...-LT_102913.pdf
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2013: 16 2014: 5 2015: 3
Old 04-26-2016, 07:51 AM   #5
Usually Confused Member
emm-dee's Avatar
I switched to E-load (Nitto) on my Ram 1500 a few weeks ago. The ride is a little stiffer but not objectionable. However, stability is way, way better than the OEM supplied tires.
Keep in mind that the Goodyear SR-A tire is about the cheapest tire GY makes. Visit some of the truck forums and you'll find the universal opinions over there compare with the opinions we all have about China Bombs. I did manage to get 30,000 miles out of the factory supplied tires.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 04-26-2016, 08:01 AM   #6
raspivey's Avatar
I run XL rated on the rears. It cuts the difference between the two. Still passenger tires, but higher pressure rated. I usually run around 45 PSI when towing and back to OEM when not. Noticeable stability difference without it riding like a tank unloaded.
2012 Chevy Tahoe LTZ - HD tow package
Old 04-26-2016, 11:39 AM   #7
RSchleder's Avatar
It may cost you a bit more, however, take a long, hard look at the Michelin LTX defenders. You can get them in a D or E load rating. I put the E rating tires on my Ram 1500 as I tow a 33ft, 7,500lb Wildcat Maxx trailer. The E is, of course, a true light truck tire with a max air pressure of 80lbs (the D lead range is more like 44lbs). I describe the ride as a bit stiffer, yet it feels MUCH more stable, and I'm totally pleased with all aspects of this tire. You do get what you pay for when it comes to tires and Michelins are tough to beat!!!!
PS-I"m running 65lbs in the tire when NOT towing and this pressure is working out fine. 75-80lbs when towing the trailer.
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 04-26-2016, 11:53 AM   #8
Stormrider151's Avatar
I put Mastercraft (Cooper) E rated tires on my F150. I run 43 lbs not towing with only slightly stiffer ride. Towing I run them at 65 lbs. makes a huge difference in stability.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-26-2016, 06:37 PM   #9
Thanks for all the feedback. Went ahead and got the tires. They inflated them to 50 psi., now I'll do some research and see what I want to run them at towing.
Thanks, again.
Old 04-26-2016, 07:32 PM   #10
Which tires did you get? FWIW, I got the Defender LTX M/S. I towed on our first trip at 50psi. It was a noticeable, but I'm going to experiment by going higher...probably try 60psi next.
500, tire
