Old 07-14-2014, 10:04 PM   #11
I have a Mini Lite 2104S. TV isa 2012 F250 extended bed. I have a 4" rise reese ball mount. Had some reservations about the amount of rise thinking that with that much lift I as asking for problems. Called Reesetalked to en engineer gave him the spect: 2 5/16 ball with a 1" shank. My tounge weight is 435#. Cap of the mount and ball 500 tounge cap total wieight is 5000. He said all was OK. STill did not feel comfortable. Bought a new ball mount with less of a rise and a higher cap. Don't need problems on our way to Goshen.
2012 F250 6.2 gasser 373 rear
2013 Rockwood 2104S Mini Lite
Ole Buzzard is offline   Reply With Quote
Old 07-15-2014, 06:08 AM   #12
TURBS's Avatar
Originally Posted by QCCowboy View Post
LOL. Made me look twice at this
Me too but figure it out as well! Lol
Old 07-15-2014, 06:37 AM   #13
Originally Posted by clickdouble View Post
Hey guys.. I was wondering..
Do you think this is safe..??
Its on a Titan and I pull a 23 feet wildwood travel trailer....
No,remove the one that is sticking out the Back,you could hit your Leg on it! Then cut some of the plastic away from the area around the Bumper ball for more clearance! Youroo!!
youroo is online now   Reply With Quote
Old 07-15-2014, 06:53 AM   #14
Engineer of Crazy Train
ChooChooMan74's Avatar
I straight balled an old 80s camper back in the 90s, but I was using an F350 dually at the time. Of course, I didn't pay attention to weight ratings back then, either, so I could have exceeded one or more ratings of the ballmount/ball/hitch w/o WDH etc. If none of the ratings are exceeded and it tows fine, then go for it.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 07-15-2014, 07:34 AM   #15
Jack of All Trades
4x4dually's Avatar
I imagine it will hold....but I'd be a lot more comfortable if the welds on that gusset were in compression instead of tension.
Oh poo. I leave my hitches in until I swap for a different one. If someone hits their shin on it.....they need to step the heck away from my stuff. If I hit my shin on it....well, a few cuss words and I'm good. LOL
4x4dually is offline   Reply With Quote
Old 07-15-2014, 08:07 AM   #16
Originally Posted by 4x4dually View Post
I imagine it will hold....but I'd be a lot more comfortable if the welds on that gusset were in compression instead of tension...
Doesn't really make much difference, the weld to attach the main bar to the 2" tube is in tension also. Best way to reinforce would be side gussets all the way over the 2" tube on both sides and up to the side of the bar where the ball is. Would put all welds in shear. Would require a socket to remove.
Old 07-15-2014, 08:11 AM   #17
Jack of All Trades
4x4dually's Avatar
Agreed. With bouncing tongue weight, that gusset will just be the first thing to go.
Old 07-15-2014, 12:52 PM   #18
clickdouble's Avatar
Thanks guys for all the recomendations...
Like i said.. I am pulling with a Nissan Titan.. 5.6 lt
With a Trailer Hitch Weight 440 lbs and Axle Weight 3,850 lbs
The ball is 2 5/16.. but the Hitch mount that I Put UPSIDE DOWN (Rise instead of Drop) dont know the specs... the reason why I put my POST...
And just to let you know.. I took it for a drive.. got to 45 mph .. and on streets.. and everything went well.. but dont wanna risk it on a long trip...
I used it because I like the level that the rise gives me.. but I think I will just use the straigt one that I have and stay away from trouble...
Thanks to all...
2006 Wildwood T23FBL
2004 Nissan Titan Crew Cab
2 Dogs-one long ears, the other not
clickdouble is offline   Reply With Quote
Old 07-16-2014, 12:41 AM   #19
Incheon, S. Korea
BigBaron's Avatar
I don't see anything wrong. What the load rating on the tongue? That's what matters.
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
