Old 03-08-2016, 12:35 PM   #11
The payload of the 2015 subi outbaks show up to 1100#s and about a 6900# gcwr. A smaller tent trailer maybe.....
What are you trying or thinking of towing?
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 03-08-2016, 12:52 PM   #12
Flybob's Avatar
I have an Outback and love it, however I would never tow at TT with it. The dealer option hitch is a 1 1/4 " receiver. You can buy aftermarket 2" hitches, but that dos not mean vehicle can handle load. I installed a 2" hitch on mine for a bike rack and the mounting will not support a 2400 lb TT. I know on mine that I can feel the difference with two additional adults especially on hills.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-08-2016, 01:25 PM   #13
prof_fate's Avatar
small pop up..haven't started shopping yet.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 03-08-2016, 02:22 PM   #14
I used to tow my 2014 Outback (4 cyl.) several trips at 325 miles or so w/ a full U-Haul & going up the mtn. home at 7,000 ft. elev. I never had a problem- it did fine.
mtnlvr is offline   Reply With Quote
Old 03-08-2016, 02:52 PM   #15
Evereddie's Avatar
Originally Posted by Oaklevel View Post
Ya Subarus are junk....... Sorry towing a 5x8 utility trailer empty (less than 1000 lbs) blew the head gaskets. It was a 2011 just over 100K just had the timing belt and water pump replaced 6 months prior........... Both head gaskets and the radiator went.......... Subaru Customer Service gave us a bunch of lip service and they said it was normal for the head gaskets on any car to go at 100K. We traded it ...The dealer fixed it and it blew up again on the new owner..........
Sorry can ya tell I do not recommend towing anything with a Subaru..... I do recommend if you keep it over a 100K when you replace the water pump & timing belt do the head gaskets too.
I have to agree with you. had several subarus and they somehow are misrepresented as being a good car. Head gaskets, oil leaks, and constant wheel bearing replacements are in your future if you buy a Subaru. I'm just sayin'.
Evereddie is offline   Reply With Quote
Old 03-08-2016, 05:26 PM   #16
Where I live in the mtns., there are loads of Subarus-about 1 in 4 ratio. They are well loved here.
Old 03-08-2016, 05:58 PM   #17
bikendan's Avatar
yea, they are really popular in the NW, but i don't see them towing anything.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-09-2016, 03:33 PM   #18
At 25,000 miles my transmission was replaced in a 2014 Subaru Outback.
It was rated for 2700 lbs towing and had trailer brakes installed. My trailer was a Flagstaff Mac trailer that had a trailer weight of around 1900 lbs. I towed at reasonable speeds, didn't floor it but did have a couple of long towing days as well as towing over mountains in the West. We don't carry much gear so we were under "towing capacity" I asked the Subaru people often about towing this and perhaps adding a transmission cooler and they seemed to think it wasn't a problem. When the warning lights came on and I pulled the Subaru with the trailer hooked up into the service area everyone suddenly told me it was too much to be towed.
There is not a gauge to record transmission temperature to even know if the transmission temp is getting too hot. My Outback seemed to tow fine and the oil temp gauge never showed a problem.
My opinion is Subaru Outback's are not made for towing the majority of popup's. My transmission repair was under warranty but buying the Outback expecting to tow a normal sized tent trailer was a costly mistake. I've learned a lot about towing weights from this forum and now know that the vehicle towing ratings are only one factor.
mwaite49 is offline   Reply With Quote
Old 03-09-2016, 03:46 PM   #19
mike.t's Avatar
No doubt because all wheel drive. How many of those tow?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-10-2016, 07:51 AM   #20
Had numerous Subies and never a single problem, from Forester, to Legacy, Wrx Sti, and now 3.6L tribeca. I also own a chevy pickup that tows my 23' boat and 27' TT. Never had issues with berings, head gaskets etc. All, and i mean all smoked little blue at startup for around 15-20 seconds - boxers are common for that. All my subies got to 200k without doing anything. No timing belts etc. There is a reason why subies are popular in snow infested areas. They're the best at that. As for towing with one, i would never tow with a Awd vehicle. Too much wear on awd power train, not efficient.
As for the post about transmission not having a gauge, i call it BS. Every subaru has red AT Temp light on dash, turn your keys to light up dash lights and you will see.
Also, if towing a small utility trailer, or going on long trips with your Subie, you can pull AWD labeled fuse, that will disable awd, and make your Subie FWD only saving you some money on mpgs
Kuba is offline   Reply With Quote
