Old 04-15-2008, 10:39 AM   #1
anyone tow with a tahoe?
Hi... yes i am new to the site and yes i have a lot of questions, but for now im only going to ask one. is there anyone here that is using a tahoe to pull their camper? if so, what model camper do you have? i have a 2003 tahoe, 5.3, 4x4, tow package (7400# max tow capacity), and no im not sure about the gears (im almost positive they are 3:73 or 4:10) but i am looking to buy a camper soon. ive actually been leaning towards the 2701ss (4900# dry, 6400# max), and yes i know most ppl here will think i should use a suburban for this (due to the length of camper vs wheelbase) but buying a different tv right now is out of the question. just thought i would see what other ppl with a tahoe are actually pulling before i bite the bullet and buy one. thanks for any input! ah, and i already have the reese dual cam wd system + prodigy brake controller.
sijc is offline   Reply With Quote
Old 04-15-2008, 01:18 PM   #2
You should not have any problems with that. I have the reese dual cam set up AND a friction brake sway controller on the side, with a shortbed ram quadcab hemi 2 wd, and I'm pulling a 30 foot 5700 lb. dry avg. 6500 lb. loaded camper,and the swaying is no problem, but I need a helper spring set up on the truck. 750 lb. hitch/tongue weight Your Tahoe's axle is closer to the hitch/tongue area, and should be better than my set- up. I also have problems with bucking (excessive bounce from bumps) that I'm hoping the helper springs take care of. Good luck, and happy camping !!
Old 04-15-2008, 08:14 PM   #3
Grape Escape
I pull Rockwood 2607 which is similar length 2005 Tahoe
LT 4x4 Reese dual cam with 800# bars. Prodogy brake control,20"wheels
Have the auto ride suspension which may not be a good thing as it sometimes defeats load distr'n bars purpose. If set up properly should work fine. We travelled approx 5000 miles last year. Only problem days were with major crosswind days. One day drove thu blowing rain storm and never felt trailer, another day bad crosswinds and a white knuckle day.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 04-15-2008, 09:55 PM   #4
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I towed a 26' er (5-6K) with an 01 Tahoe Z71 4x4. I used an Equal-i-zer brand hitch (built in sway control) and a Prodigy. It towed pretty well. I did upgrade the tow vehicle, because I was too close to the limits. (and the rear diff disentigrated...factory defect I was told) The same trailer with the same hitch towed MUCH nicer with my Nissan Titan. That longer wheelbase, taller gears, and more powerful engine really improved the tow.
My advice:
Tow with black/gray/fresh tanks empty.
Load light as possible, with weight distributed correctly.
Tow at a slower speed than you'd like to.
Use the best hitch you can afford. (and the Prodigy is sweet!)
Drive defensively, and be careful in bad weather/winds.
If you have any sway issues...solve them. Don't risk a nasty wreck!
Oh...and have fun!
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 04-16-2008, 09:33 AM   #5
hunt4240dw's Avatar
Send a message via MSN to hunt4240dw
As you see in my sig, I tow with a 99 Tahoe. The Vlite has a brochure weight of 5700#. It has a dealer lot weight of 6215#. And it will weigh about 6700# when camping. I am having a little prolem with sway but that is a prolem with set up only. I have an Equal-i-zer hitch and Odessy brake controller. On our first trip ( 300 mi round trip) we got 11 mpg. I have to tow in 3rd. I do not have tow haul mode. I next trip will be the weekend of the 4/25. I hope I can tow at 65 mph.
David
The Hunts
2012 F150 Ecoboost, 3.55, tow package
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
hunt4240dw is offline   Reply With Quote
Old 04-16-2008, 12:26 PM   #6
I have a 2701ss and we originally planning on using our 04' Expedition (5.4L 3.73 gears) to tow with. The trip home from the dealer was using the Expy and it was not bad. I also have the Reese DC setup and the trailer did not have a sway issue. The shorter wheel base on the Expy, 119", was noticable especially when you hit bumps in the road around curves or when I was in between 2 lanes. I could feel the trailer trying to move the rear end around a little. Wasn't horrible, but noticable.
Hope that helps a little.
Brian
2008 Rockwood 2701ss
2008 F-250 Lariat 4X4 6.4L PSD
Reese DC WD hitch
bricole1973 is offline   Reply With Quote
Old 04-16-2008, 01:07 PM   #7
Rockinwood's Avatar
We use to tow a 31 foot Keystone Outback with an 03 expy, 5.4l, with dual cam and had no problems, just take your time and have fun.
In regards to the Surburban, this group of people here are down to earth and dont act like the weight police, and they are honest about what they use for their tow vehicle, Good luck to your decision and Happy Camping!!!
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 04-16-2008, 01:34 PM   #8
Weight police ARE NOT welcome here. There are other places for them to chime in. FRF isn't the place.
aintgotnun is offline   Reply With Quote
Old 04-16-2008, 06:43 PM   #9
jmyers's Avatar
When we bought our Sandpiper I planned to pull it with our '99 Tahoe. I pulled it 30 miles from the dealer to home and never hooked the Tahoe to it again. It was not a pretty scene. I have the Reese Strait-Line system and, at the time, a Voyager brake controller. Although my WD may not have been set up exactly perfectly, I don't think that was my problem. The 3.42 rear end and the short wheelbase were my problem. (Not to mention the worry of burning up the tranny.) With a 30' trailer weighing 7K# dry, the Tahoe just didn't do what I wanted. Maybe others have had better experiences than mine, but my Tahoe will never pull my Sandpiper on the road again.
My driver's license says my name is "Jeff"
2000 Chevy 2500 4/4 6.0/3.73
2002 FR Sandpiper 30FKSS
Reese Strait-Line
Prodigy
DW
DD (Darling Dachshund)
jmyers is offline   Reply With Quote
Old 04-17-2008, 05:35 AM   #10
I don't know how true it is but from what I understand, if you tow a TT over 25' with a short wheel base vehicle you end up with more sway. I tow with a Suburban and my rig is approx 34', my total length is approx 55'.
Old 04-17-2008, 07:03 AM   #11
Super-Duper Member
ReedMan's Avatar
My neighbor pulls his Layton 26' with his Tahoe and has no problems.
Check your tires. Most of the tires on Tahoe's are NOT LT rated tires (They are passenger car tires for a softer ride). He said that when he upgraded to the stiffer sidewall LT tire, the truck didn't "wallow" (his words) any more.
Bones
ReedMan , Wife , Three Kids 2x 1x
2002 Flagstaff 25LB (Triple Bunks!)
2001 Chevrolet Silverado Z71 1500 LT Sport Side
ReedMan is offline   Reply With Quote
Old 04-17-2008, 07:56 AM   #12
Question? If the Tahoe has a factory tow pakage, should it come with the proper tires? My Suburban has 10 ply tires on it ( load rated "E" ) for up to 10,000 lbs.
Old 04-17-2008, 08:06 AM   #13
i appreciate all of the input, hopefully when it comes down to it i will make the right choice on what camper i get. if not ill be making REALLY short trips, which most of our trips will be under 500 miles anyways. im going to look at a new 2701ss next weekend, maybe they will let me try pulling it down the road before i actually buy it. im not too concerned with the tahoe actually pulling it though... my main concern is the sway. seeing how ive NEVER pulled a camper before i dont need the added stress of a camper swaying all over the road. tires are something i need to look into since the tahoe has some really cheap passenger "hankook dynapro" tires at the moment. anyone have any suggestions for good tires on a tv? im also planning to swap out the intake + exhaust to get a lil extra horsepower (im hoping). i was going to to one of the performance chips but ive hear a lot of ppl say it doesnt help much on gas engines... plus the tahoe already has the tow/haul button on the steering column, which from my understanding does about the same thing a chip will do while towing?
Old 04-17-2008, 04:57 PM   #14
Grape Escape
I think you should be fine
I have no issues pulling our trailer as long as you are reasonable, stay within the limit (no more than 60 MPH) and not drive as if you are driving a sports car. I am amazed at the idots flying by me on the highways pulling all sorts of rigs. Sooner rather than latter they will be in an accident.
