Old 06-25-2014, 08:20 PM   #11
the-the-the- The GRINCH!
DaGrinch's Avatar
Originally Posted by RhoZeta View Post
These look a little different from the equalizer I used to have. Mainly the hole for the retaining pin in the L pin was BELOW the L bracket. Just from what I can tell in pic it would seem possible for L pin to come off? Is there another hole that the retaining pin is going thru under the L bracket?
Those are the new style pins. There is NO hole for the pins you are talking about to go through.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
Old 06-25-2014, 08:25 PM   #12
Who Dares, Wins
doc73's Avatar
Pics of hitch mount:
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon-EOW 11/22/2017
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 06-25-2014, 08:27 PM   #13
Who Dares, Wins
doc73's Avatar
Originally Posted by Capt. Mike View Post
The one shown in these pictures is the latest design from Equalizer. I just got a set of those from the factory. My original ones are like you described: Two separate pieces, the L bracket and a pin that went through it, below the bar rest. The new ones are designed so that you can't lose the pin.
Equalizer also makes a plastic pad that goes on top of the bracket, below the WD bar. It would take up some of that space that we're seeing in the picture. They are called Equal-I-zer friction pads. You can find them on Amazon.com. Sorry, I can't seem to get to amazon right now, or I'd give you a link.
I had heard they did not make them yet for the new pin style.. (might be wrong)
2015 ChevyHD D-Max
Old 06-25-2014, 08:34 PM   #14
DaGrinch's Avatar
[QUOTE=doc73;643903]Pics of hitch mount:
/QUOTE]
After I posted the picture of mine, I went to Progressive's web site and saw the new set-up. I see now. I also need to go to Tractor Supply and get me a set of these.....
I'm tired of trying to put those little pins in the holes with gloves on.
Thanks for taking the pics.
Old 06-25-2014, 08:55 PM   #15
Capt. Mike's Avatar
doc,
I just got the friction pads from Equalizer, along with a set of the "new style" pins. I haven't tried to put them on yet, but I will in the next day or so. Just taking them out of the package and eyeballing them, it looks like they should work. I'll let you know.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
ďIt's not how old you are, it's how you are old.ĒJules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 06-25-2014, 08:57 PM   #16
mshell56118's Avatar
Originally Posted by DaGrinch View Post
On my pins, yes, I have a bit of play initially when I put the bars on.
Now, I have a question for you, doc73......
Could you take a picture of the way your "L" brackets are attached? It appears they are attached with bolts and lock nuts. Mine slide into the bracket attached to the frame and then the "L" is secured by a single bolt.
Yeah, I know, the brackets need to be touched up! That's on the list for this weekend.
You have a older style. I bought a used set and could not find any setup info I emailed equalizer and they sent me the manual
Sent from my iPad using Tapatalk
mshell56118 is offline   Reply With Quote
Old 06-25-2014, 09:07 PM   #17
DaGrinch's Avatar
Yeah, the whole Equal-i-zer rig is 6 years old now. But, with some TLC now and again, it still works like a charm.
equalizer
