06-25-2014, 04:04 PM
Who Dares, Wins
Are this normal for equalizer pins?
I know the title is not very helpful but I was not sure what else to say...
Pics:
There is play in the pins but I was unsure if this was OK. The other side remained tight. It may not make a difference but I am still new with this hitch so I wanted to confirm. The pins are not bent, the mounts are fine. The pins just have some play.
2015 Chevy HD D-Max
2022 Impression 315MB
06-25-2014, 04:47 PM
Mine have no play until I relieve pressure to remove bars.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
06-25-2014, 05:53 PM
Who Dares, Wins
Ok, sorry... let me clarify. I do not have wobble when the bars are in place. The pins are locked in place then. My question was really is it ok that the pin moved from being tight against against frame. The wobble is only when the pins are in place without the bars in place.
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
2015 Chevy HD D-Max
06-25-2014, 06:04 PM
Some play in the pins is normal when the bars are not attached or applying pressure (mine is the same at any rate).
06-25-2014, 06:18 PM
Who Dares, Wins
Ok good. I thought it was fine but I was not sure since it is only three trips deep with me.
2015 Chevy HD D-Max
06-25-2014, 06:48 PM
Infractee
These look a little different from the equalizer I used to have. Mainly the hole for the retaining pin in the L pin was BELOW the L bracket. Just from what I can tell in pic it would seem possible for L pin to come off? Is there another hole that the retaining pin is going thru under the L bracket?
06-25-2014, 07:15 PM
DW's 401(k) Plan
On my pins, yes, I have a bit of play initially when I put the bars on.
Now, I have a question for you, doc73......
Could you take a picture of the way your "L" brackets are attached? It appears they are attached with bolts and lock nuts. Mine slide into the bracket attached to the frame and then the "L" is secured by a single bolt.
Yeah, I know, the brackets need to be touched up! That's on the list for this weekend.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
Who Dares, Wins
No it does not do anything but hook under the bracket. I guess it could come out but when the bar is in place it puts some pressure on the pin so I do not think it could come out. I guess I have the new style pins.
2015 Chevy HD D-Max
06-25-2014, 07:17 PM
Who Dares, Wins
I will get some pics
2015 Chevy HD D-Max
06-25-2014, 07:19 PM
The one shown in these pictures is the latest design from Equalizer. I just got a set of those from the factory. My original ones are like you described: Two separate pieces, the L bracket and a pin that went through it, below the bar rest. The new ones are designed so that you can't lose the pin.
Equalizer also makes a plastic pad that goes on top of the bracket, below the WD bar. It would take up some of that space that we're seeing in the picture. They are called Equal-I-zer friction pads. You can find them on Amazon.com. Sorry, I can't seem to get to amazon right now, or I'd give you a link.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
06-25-2014, 07:20 PM
DW's 401(k) Plan
Those are the new style pins. There is NO hole for the pins you are talking about to go through.
06-25-2014, 07:25 PM
Who Dares, Wins
2015 Chevy HD D-Max
06-25-2014, 07:27 PM
Who Dares, Wins
I had heard they did not make them yet for the new pin style.. (might be wrong)
2015 Chevy HD D-Max
06-25-2014, 07:34 PM
DW's 401(k) Plan
[QUOTE=doc73;643903]Pics of hitch mount:
/QUOTE]
After I posted the picture of mine, I went to Progressive's web site and saw the new set-up. I see now. I also need to go to Tractor Supply and get me a set of these.....
I'm tired of trying to put those little pins in the holes with gloves on.
Thanks for taking the pics.
06-25-2014, 07:55 PM
doc,
I just got the friction pads from Equalizer, along with a set of the "new style" pins. I haven't tried to put them on yet, but I will in the next day or so. Just taking them out of the package and eyeballing them, it looks like they should work. I'll let you know.
Mike and Yvonne
06-25-2014, 07:57 PM
You have a older style. I bought a used set and could not find any setup info I emailed equalizer and they sent me the manual
Sent from my iPad using Tapatalk
06-25-2014, 08:07 PM
DW's 401(k) Plan
Yeah, the whole Equal-i-zer rig is 6 years old now. But, with some TLC now and again, it still works like a charm.
