Old 01-02-2016, 09:49 PM   #1
Automatic leveling suspension
New to towing. My TV is a 2015 Navigator with automatic leveling suspension. Vehicle manual says to drive a few miles to allow to level, measure height of front wheel well; attach trailer without weight distribution bars and measure again. After pulling a couple of miles, allowing suspension to adjust again, remeasure and apply weight distribution bars. Then adjust tension to halfway between first and second measuring. This results in third chain link. My question is do I have to do this every time, or can I simply use the third chain link from the start on future trips? I'm thinking I will need to allow the truck to "level" before I attach bars each time. Appreciate any help.
Buzzard Bait is offline   Reply With Quote
Old 01-06-2016, 09:13 AM   #2
I have a GMC Yukon Denali with auto ride feature...which is auto leveling. We just hook up the TT with WDH and once the engine is started, the compressor adjusts the rear to a level position compensating for the tongue weight. My dealer installed the WDH and explained the procedure. I'm also at 3 links. When I park and turn off the vehicle you can see the rear end go down after a bit, start the engine and it goes level in a minute or so.
martinto is offline   Reply With Quote
leveling, suspension
