Old 09-11-2010, 08:12 AM   #1
Question Axle ratio???
My Jeep GC has an axle ratio of 3.55:1. I was checking out the manual last night (never opened it in 5 years!), and noted that for class III (GTW 5000 lbs max) the 'requirement' is an axle ratio of 3.73:1. When we purchased the vehicle, we weren't towing at the time so we did not get the towing package which would have included this axle ratio.
How big of a deal is this? It doesn't 'seem' much bigger but what do I know about axles and axle ratios. From what I can gather, it seems having a lower axle ratio would decrease the amount I can tow but it doesn't seem it would decrease by a significant amount.
What's the impact of having 3.55 instead of 3.73?
We mostly tow in the flat midwest (IL, WI, MI, etc.). At least, for now...
Thx,
Deena
peasedm is offline   Reply With Quote
Old 09-11-2010, 08:27 AM   #2
archham's Avatar
First, we need to clear up the semantics. A "lower" gear ratio is generally considered to be a higher numeric number - the 3.73 is a lower gear than the 3.55. A "taller" gear ratio is a lower number numerically. Don't know if you ever had a 21 speed bike, but think of the rear sprocket as your transmission with 5 speeds or whatever and the front sprocket as the "rear gear" - except you dont get to change it on the GC like you do on the bike. The bigger sprocket is harder to pedal - the 3.55 is a bigger sprocket than a 3.73 is.
If you don't have the towing package, you probably don't want to tow a TT, regardless of the gear ratio (you probably don't have trans oil cooler, heavy duty alternator, etc.).
The lower gearing will make it much easier on your transmission while towing - the engine power is not the issue here. I am towing with 3.31 gears in an F150 (8,100# tow limit - I am pulling about 4k) with no problems at all.
I am sure most here will tell you to stick with the mfg. reccomendations, I don't think I would tow a TT (maybe a pop up) without the tow package.
2012 Puma 30FQSS
2005 Ford F-250 Super Crew 6.0 PSD
2003 Honda Odyssey
1 wife, 1 son, & 1 cat
Volunteer Firefighter/EMT
Asst. Scoutmaster (BSA)
archham is offline   Reply With Quote
Old 09-11-2010, 08:51 AM   #3
Thanks for the explanation about the axle ratios! Makes sense now...
The tow package for Jeep GC included trans oil cooler, the 3.73 axle ratio, a receiver and plug adapter. The only thing I'm missing is the 3.73 axle ratio. We added the trans cooler, receiver and wiring...
I've read elsewhere that axle ratios below about 3.3 should consider limited towing and that 3.5 to 4 is adequate. Opinions?
I can have the vehicle re-geared, just wasn't sure it was worth it given the size of our TT.
Thanks!
Old 09-11-2010, 09:53 AM   #4
NWJeeper's Avatar
Deena, We have a 2005 Jeep Liberty with the tow package, it is rated for 5000lbs. I only tow a 20' bass boat with ours but at 3700lbs it is about the same weight if not more than the Jeep. I have to tell you I don't like the way it tows. Luckily we don't have to use the Jeep to tow very far usually only to launch when we are out camping. I intend on getting something like an F150 next year so we can tow longer distances if need be.
I have never liked Jeeps of any sort for towing. They just aren't a good stable platform for it, usually being short wheelbase and narrow which doesn't give a good stance for it. Also, SUVs always come from the factory with soft suspensions and "car" tires that are meant for a smooth ride but aren't well suited for towing.
Regearing your Jeep would likely run around $900 per axle for new gearsets and installation. I would recomend finding a good used F150 instead of, as we say in the Jeep world, "throwing good money after bad".
As others have stated you would be fine with a small pop up but for larger trailers I wouldn't be using your GC for it.
Ed & Wendy
www.nwjeepn.com
Old 09-11-2010, 10:20 AM   #5
Axle ratio has everything to do with performance and little to do with towing capacity. Your 3.55 rear ended Jeep will pull the same load, just not be very happy doing it. While not an ideal gear ratio for towing, a small tent trailer or Aliner would be fine. Just keep a close eye on your actual weights and do not try to overload it.
Old 09-11-2010, 10:35 AM   #6
Well, we towed the TT last weekend, short trip, about 2.5 hours and it seemed to do okay. Didn't have any overheating issues, in fact I was surprised because the temp was the same as it runs without the TT attached. We're taking the TT to get weighed today, it still falls within the allowable limit for the TV but of it sounds like another TV would be ideal. We'll probably use is 1-2 more times this year before putting it in storage until the spring and don't really plan on any long trips. It's mostly flat land out here.
My husband is getting rid of his car next year so we'll probably pick up something a little more suitable rather than regearing the GC. Suggestions? We need seating for 4 and an area in the back for the dog. Envoy maybe? Should I always be going for an 8-cyl? What else do we look for?
Old 09-11-2010, 10:47 AM   #7
We need to know the GVWR of your travel trailer to be able to give you any meaningful answer, other than get an F-350 with a Diesel You are in a good position as you already have your travel trailer and need to choose a suitable tow vehicle. If you give us the GVWR of the TT (Not the UVW, it is always safe to assume that you will be at or close to the GVWR as weight accumulates over time in a TT) and the number of people which will travel in the TV, then I am sure members will start giving you recommendations. if you could also include the length of your TT, even better the make and model of it, it will help everyone to come up with suggestions.
I am guessing that you prefer a capable SUV to a pickup truck ? And I will risk saying, no 6 cylinders please .....
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 09-11-2010, 11:14 AM   #8
The trailer GVWR is 4800 lbs. and it's 18' in length. It's a 2010 Dutchmen Sport 716fd.
4 people (2 adults, 2 kids), 1 dog in the TV.
Would definitely prefer a capable SUV rather than a pickup, we can confine the dog in the back.
Old 09-11-2010, 12:29 PM   #9
Herk7769's Avatar
Sounds like a Chevy Suburban or GMC Yukon (same vehicle) 1500 would fit the bill for what you currently have. However, might I suggest you would be happier with the 2500 series (3/4 ton chassis). If you decide you want a larger camper at a later date you would be good to go without buying another tow vehicle.
HAM CALLSIGN - KC3FFW
Old 09-11-2010, 12:32 PM   #10
NWJeeper's Avatar
X2 what Herk said. RVs are a strange thing, I can almost guarantee you will be upsizing in the furture (as most of us have ) so plan ahead and go bigger on the TV right now.
Ed & Wendy
www.nwjeepn.com
axle
