Old 07-08-2012, 08:49 PM   #1
Mark S's Avatar
Axle Weights From Scale - help understanding
Four thousand miles into my trip, I decided to weigh my truck and trailer. My 2011 F150 Ecoboost 4x4 SCREW with 373 rear is pulling my Work and Play 18EC toy hauler with an advertised dry weight of about 5,200 lbs. In the trailer is my 800 pound Harley as well as all our other stuff. I am averaging a little above 10 mpg at 60-63 mph.
From the scale ticket:
Steer axle 3,300 lbs
Drive axle 4,180 lbs
Trailer axle 6,160 lbs
Gross weight 13,640 lbs. (manual lists my truck at max GVW as 15,500)
I am not sure I understand the axle weights. I am using a weight distributing hitch and the truck is pulling really well with the exception that on some bumpy roads the rear sometimes feels a little soft.
Are these numbers good? I know the trailer weighs more than the 6,160 with all our stuff in it. Is the 880 pound difference between the front and rear axle ok? The truck is steering well.
I think I might have felt better not knowing all this.
Any feedback will be appreciated.
Thanks, Mark
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 07-08-2012, 09:58 PM   #2
Dave_Monica's Avatar
Should have weighed the set-up with the W/D bars disconnected to determine the amount of weight you're transferring and where. A weight of the truck alone would also have determined the campers tongue weight.
With the weights you have you can compare them to the truck's specs for GVWR and FAWR/RAWR. Unless your truck has the max tow option, you may be over the truck's GVWR and RAWR.
Dave
axle
