Old 10-15-2013, 08:17 PM   #1
pjones1969's Avatar
B&W Companion has been redesigned
In case you haven't seen this, the B&W Companion has been redesigned and is rated for 20k now and some other nice features.
This new model, RVK3500, is starting to hit the marketplace as distributors work through their inventory of model RVK3000.
http://www.turnoverball.com/products...th-wheel-hitch
Higher Weight Rating
20k instead of 18k. Truck ratings are going up. Bigger, heavier fifth-wheel trailers with more slide-outs and space for toys are gaining in popularity. This new Companion is stout, and 33 pounds heavier than the 3000 model.
More Height Adjustment
14.75” to 16.75” was the height adjustment with the Companion 3000. 16.25" to 18.25” is now the adjustment with the Companion 3500.
No More U-Bolts
The post that attaches the Companion through a single point to the mounting system below the bed, now uses bolts instead of U-bolts making it more user-friendly.
Adjustable Foot Pads
Adjustable plastic feet fill in the bed recesses, allowing the Companion to be used in more applications.
New Post Allows for Forward to Aft Adjustment
Now the post can be mounted in two different towing positions relative to the truck axle. This will allow it to be used in more applications, including the 2013 Ram 3500 pickups. In addition, a shorter post (RVP3521) is available for use with the Toyota GNRK1257 and Dodge GNRK1309.
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
