Old 03-03-2014, 07:09 PM   #11
LaydBack's Avatar
If it falls through, I got my whole setup on eBay for about $1125
Sent from my SPH-L710 using Forest River Forums mobile app
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 03-03-2014, 07:33 PM   #12
Oklahoma Proud
MillerTime's Avatar
Originally Posted by RodeoGeorge View Post
As mentioned above, the newer version of the Companion does not use the "U" bolts.
#1 If you recently purchased the hitch I would contact the dealer and tell them that you want the latest version.
#2 You can contact B&W and see if the newer post can be used with the original version of the Companion.
I have the "Flat Bed" version, which did not use the "U" bolts, but required a reinforced area where the hitch sits in the bad.
RodeoGeorge
No the new post won't work on the older companion.
They sent us a new post with the lower hole setting in it for a dodge hitch, but it wouldn't fit my hitch.
And yes you do have to torque this draw down bolt too. But no u bolts so much quicker
MillerTime- Future Sabre Handler!!
ID:	47108   Click image for larger version
Old 03-03-2014, 07:46 PM   #13
Oklahoma Proud
MillerTime's Avatar
Originally Posted by WoodyMccloud View Post
I have the B&W hitch, and no torque is required. There are no bolts to loosen when switching back and forth between 5th wheel and goose neck. Mine is attached to a square rod that comes out with the hitch. Then I just drop in the ball for the goose neck and release the locking pin. Maybe the second pin that is attached was an add on from the dealer.
Another owner said the same thing a couple of months ago.
This is not how the manufacture states to do this.
You HAVE to tighten the draw down bolt to 40 ftlb. Then the ubolts tightened and torqued evenly to 80 ftlb. This eliminates any slack and decreases the likelihood of the pin shearing from rocking and jerking.
If you can remove ANY of the companion hitches without loosening any bolts, or if your lower pin moves at all, then the hitch is NOT INSTALLED CORRECTLY and is not safe to use.
If you have torqued in the correct sequence and the lower pin still moves, contact B & W and they will help you figure it out and help you with replacement parts.
THIS POST IS FOR THE SOLE PURPOSE OF INFORMING PEOPLE AND TO KEEP EVERYBODY OUT THERE SAFE.
**** These are the manufacturers torque sequences, and can be verified on thier website for free, or in your owners manual****
Ps. I've put in a "few" of these
Old 03-03-2014, 07:46 PM   #14
Suggest you review the video "How to Install B&W 5th Wheel Hitch." This clip narrated by Chris Long, of Long hitches explains the features of the new B&W and how it does not use the U-bolt assembly
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 03-03-2014, 07:51 PM   #15
Oklahoma Proud
MillerTime's Avatar
Correct, the new hitches do not use the u-bolts.
But ... they still use the draw down bolt to tighten the lower pin.
( you can see the hole for the 3/4" head bolt in the top view pic I posted above)
Here ill show again
Old 03-03-2014, 08:01 PM   #16
Oklahoma Proud
MillerTime's Avatar
Here's the instructions screen shotted from B&W's pdf for the new companion
Note the torquing of hitch in step #6
ID:	47114   Click image for larger version
ID:	47115   Click image for larger version
ID:	47116   Click image for larger version
Old 03-03-2014, 09:13 PM   #17
Owner/Operator
RodeoGeorge's Avatar
Millettime,
Those are the instructions for the Flat Bed version of the hitch, if I'm not mistaken.
The instructions for the one designed for a standard pickup bed are different.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 03-03-2014, 10:49 PM   #18
Oklahoma Proud
MillerTime's Avatar
Yes sorry. They had better graphics than the pencil line type drawings.
The in-bed old style (3000) is the same with tightening of the u bolts after the draw down bolt.
The new in-bed style (3500) is the same with the exception of adjusting pad feet to go between ribs in bed and a single draw down bolt that torques to 60 ftlb if I remember correctly.
Same principle on all 3- post (or post insert on 3500) snuged up against lower pin.
Old 03-04-2014, 09:30 AM   #19
only takes a couple minutes to torque the bolts. Plus the B&W is two pieces that can be handled by one person
Rockwood 8282 WS
2012 F-250 6.2
farfetched is offline   Reply With Quote
Old 03-04-2014, 09:32 AM   #20
Retired CSM
OK folks, it looks like I need to tell you that I was wrong (or better yet, misinformed). I had my hitch installed by a 3rd party as part of my new truck purchase. Therefore I was instructed on how to use the hitch by the Chevy dealer. After reading your posts and doing more research and then calling the B&W folks, it turns out that MillerTime is 100% CORRECT. I'm glad that I never hooked up the 5er after putting the hitch back in my way. There is the requirement to re-torque the bolts, because there is a requirement to loosen them when you remove the hitch and go to the gooseneck. Thanks for the catch MillerTime. I am torqueing tonight, so I am ready to pull this weekend. I LOVE THIS FORUM!!!! Lots of smart folks here.
2013 Chevy 2500HD Duramax
2014 Crusader 330MKS Touring Edition
WoodyMccloud is offline   Reply With Quote
hitch
