Old 03-03-2014, 05:12 PM   #1
D-maxx dave's Avatar
B&W hitch
Okay, couldn't find info I wanted by searching, so:
I was sold on B&Ws companion hitch, til I saw video on u-tube. Do I have to tighten u-bolts and retorque set pin every time I remove it from truck bed? And if so, is there another comparable hitch out there? I need the clean bed, and I'm sure turnover hitch will be a good item at trade in time, but I thought removal would be easier.
Remember, I'm new to fifth wheels!
D-maxx dave is offline   Reply With Quote
Old 03-03-2014, 05:22 PM   #2
LaydBack's Avatar
I own it, and it's not a hard thing to do. I say that, but I don't take it out on a regular basis, but to answer your question, yes you have to do that process every time.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 03-03-2014, 05:27 PM   #3
doodler's Avatar
Yes you do have to loosen u bolts and loosen torque bolt or vice versa every time you install or remove it. If not it would not be tight enough against latch pin. At least that is the way I understand the instructions and the way I do mine. I Do not know what is comparable model.
doodler
doodler is offline   Reply With Quote
Old 03-03-2014, 05:45 PM   #4
golfmedik's Avatar
I own the hitch and yes, you need to re-torque it every time you take it out. When it is re-installed, you need to torque the draw down bolt to 40 Ft lbs and then tighten the U-bolts to 80 Ft lbs. The newest version of the hitch does away with the u-bolts and has a new post to anchor it with. As far as the B&W hitch, as far as i am concerned, there is no better hitch on the market and they have the BEST customer service department you can imagine. Plus, the absolute best part it that there hitches are 100% Made in the USA with American Steel.
Monty
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-03-2014, 05:53 PM   #5
Fulltime family RVer
All of the above EXCEPT that the new generation of Companion hitch doesn't require the u-bolts any more.
The torquing it is easy- you have to tighten the bolts anyway, it's simple to use a torque wrench.
ependydad is online now   Reply With Quote
Old 03-03-2014, 06:05 PM   #6
Owner/Operator
RodeoGeorge's Avatar
As mentioned above, the newer version of the Companion does not use the "U" bolts.
#1 If you recently purchased the hitch I would contact the dealer and tell them that you want the latest version.
#2 You can contact B&W and see if the newer post can be used with the original version of the Companion.
I have the "Flat Bed" version, which did not use the "U" bolts, but required a reinforced area where the hitch sits in the bad.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 03-03-2014, 06:08 PM   #7
Retired CSM
I have the B&W hitch, and no torque is required. There are no bolts to loosen when switching back and forth between 5th wheel and goose neck. Mine is attached to a square rod that comes out with the hitch. Then I just drop in the ball for the goose neck and release the locking pin. Maybe the second pin that is attached was an add on from the dealer.
2013 Chevy 2500HD Duramax
2014 Crusader 330MKS Touring Edition
WoodyMccloud is offline   Reply With Quote
Old 03-03-2014, 06:21 PM   #8
Woody, when did you get your hitch? It sounds like you have the new Companion version.
Old 03-03-2014, 06:30 PM   #9
Retired CSM
I got my hitch last year. . Not sure if it is a newer version or not. I have switch it back and forth couple of times, and I like how easy it was.
Old 03-03-2014, 06:31 PM   #10
I love this forum!!!!!
Ok! I'm sold! Haven't purchased yet, but depending on what my dealer says about my trade-in, I'll be installing this wknd . Actually may have found a second hand turnover from a buddies converted race truck! I can't believe the response time on this forum, and tho I'm usually hesitant(hardheaded) about taking advice, I have confidence in the answers I've read here ! Thank you , and maybe I'll be able to help someone out somehow/way!!
hitch
