06-26-2009, 11:31 PM
backing up with wd hitch and sway control
I've heard that you can't back up with sway controllers. Is this true? Is it just friction style or dual cam aswell. It seems every dealer I talk to tells me something different.. I'm getting the feeling non of them have a clue, they just want to sell me what they stock, and dont care about me getting the "best" setup. Some of these guys haven't even heard of the cam style, and they sell trailers. Any insight is appreciated.
06-27-2009, 12:11 AM
I have the Blue Ox WDH and have no problem backing up. When I was researching hitches, all the ones I was looking at were able to go in reverse.
06-27-2009, 12:23 AM
I did have a EAZ-LIFT with friction sway control, no problems backing up with the sway control attached. I now have a Dual Cam, much better setup, no problems backing up with the bars attached.
2010 Wildcat 30LOFT
2011 RAM 3500 CCLB Cummins
06-27-2009, 06:03 AM
I was always told to remove the friction anti-sway when backing up and when making sharp turns. I now have an equil-i-zer which has built in anti-sway and there is nothing to remove.
06-27-2009, 08:27 AM
i was told the same thing remove the anti sway bar before backing up .The WD bars are ok to leave on but at least take the tension off the sway bar first. I guess it cant hurt to remove it better than trashing the anti sway bar just in case
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
06-27-2009, 09:26 AM
This is also what I was told and have always done.
06-27-2009, 09:42 AM
You are correct, most of the time the dealer is just looking to sell what they can make money on, sad but true. The dealership where we got our TT set me up with a regular WDH and a single sway bar, I never felt confortable or safe towing this big TT. It is recomended that you remove that sway bar when backing up into tight places. Now we have an Equal-i-zer hitch, I love that thing, pretty easy to set up. Best money I've spent so far when it comes to confort and safety when towing. You should check them out http://www.equalizerhitch.com/
2007 Forest River Cherokee 30F
* 14K Equal-i-zer hitch
* TST tire pressure monitor
2003 Chevy Silverado 2500HD Duramax
* 4" MBRP exhaust
* AFE stage2 air intake kit
* Hypertech III, set on stage1
* back-up camera
* Putnam XDR class V hitch receiver
* Airlift air bags
2004 EZGO custom electric golf cart
06-27-2009, 10:33 AM
every setup with a friction bar i've seen required you to disconnect it before backing up. if you didn't have to turn much you could get away without doing that.
this is why i bought an Equal-i-zer. 4-point sway control without having to disconnect anything. you set it up and forget it. i've had to go nearly 90 degrees backing up without
any problems.
and there's no chains to deal with.
06-27-2009, 09:57 PM
thanks for the replies. It looks like I'm going to go with the Reese Straight Line setup, and from your responses I wont worry about taking it off to back up, unless I have to knife her into a tight spot.
06-29-2009, 03:35 PM
No need to change anything when backing with Dual Cam Reese.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
06-29-2009, 10:11 PM
Looked at my old install instructions for my friction sway control and it states:
"If you can hit the sway control while in a jackknifed position, you must remove the sway control while backing."
2010 Wildcat 30LOFT
07-27-2009, 09:16 PM
I have a Hensley Arrow, although horribly expensive, I can back in at almost a 90 degree angle.
2008 Cadillac Escalade
2010 Surveyor SV-294
Hensley Arrow Hitch
Hensley TruControl Gold Brake Controller
07-28-2009, 07:45 AM
I have the Equalizer hitch as well, only WD hitch I have ever used. My only complaint is that it seems to be VERY loud - lots of creaking & moaning noises when I make a turn or back up. It is brand new - only pulled with it twice. I will try greasing it, assumed the dealer greased it before we left after they set it up. Anyone else having this issue? Or is it normal?
07-28-2009, 01:49 PM
I understand that the Equalizer creaks, moans, and pops just like my Reese Dual Cam. It is an attention getter at the campgrounds
Just consider it as making a grand entrance.
07-28-2009, 04:29 PM
I have a Reese Dual Cam and the instructions are to NEVER grease it. It works on Friction, and the grease will eliminate the friction, therefore reduce or eliminate it's ability to function properly. Reese says you may use a little Vaseline on the cams. Tried it and it still pops and moans. Not sure about the Equalizer, but check before greasing or you may render your sway control useless.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
07-29-2009, 07:15 AM
I too use Vaseline on the cams, and it seems to quiet things down for awhile, but I guess once the metal to metal forces the vaseline out, it gets noisy again.
I would think that using any kind of lubricant on a Equalizer system would be a no-no, as the system using friction pads to control sway.
07-29-2009, 07:19 AM
You actually can grease the Equal-i-zer. There are instructions for doing it on the website. I grease the L brackets on mine and it makes it much quieter. I'm sure it reduces the sway contol a bit but I haven't noticed it any.
Gotta go campin!
07-29-2009, 07:36 AM
It certainly will make a grand entrance that is for sure - we were pulling it around the neighborhood Saturday and really turned some heads with the noise. Some of the moaning noises remind me of me after eating at Taco Bell! I think I will grease it some, my 210 is small enough that I can probably give up a little sway control if it comes to that.
08-07-2009, 10:03 PM
I had a easi- lift before and sold it with the old trailer. I broke a hitch knob off when I forgot to disconnect it when backing up. I now have a equalizer 4 way with my new trailer and don't have to bother with anything, just drive.
08-09-2009, 10:58 AM
I have the Equalizer as well. I am a newbie and have not towed with any other type of WD hitch. The dealer was adamant about how much better it was over traditional WD hitches and would not sell anything else. I think I paid too much for it, but they took care of all the setup. It is VERY loud when making turns - I am going to try to grease it (have only used it twice) to see if that helps before using it again.
I have found that you have to basically have the TV and TT in a straight line to get the bars off when un-hooking. If not lined up, one of the bars will not come out (the "inside" bar). Are other WD hitches this way?
