Old 05-23-2012, 01:12 PM   #1
Fire Instructor's Avatar
Backing-Up with Weight Distribution Hitch
I've read and heard in past discussions that you shouldn't back your TT up with a Reese Dual-Cam WDH. Besides the noisey creaking sounds, why not? Does the WDH make turning the wheel while backing less responsive?
I've got a tough driveway to back into, and I'm curious if pulling down the street past the driveway, releasing the torsion bars, and then backing in would make it better or worse?
Couldn't locate anythng on the subject n the Reese website....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 05-23-2012, 01:46 PM   #2
TURBS's Avatar
I backed mine for 6 years with no issues.
Just removed for tight turns
Old 05-23-2012, 01:49 PM   #3
Brigitte
boubou's Avatar
Great question! I'll try taking the bars off to back off just to see if it's easier or the same
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 05-23-2012, 02:21 PM   #4
In the 36+ yrs of using a wdh, I recall only one time of unlatching the torsion bars and that was when I was stuck @ a racetrack and wanted more weight on the rear wheels. Once I got out, hooked them back up. Never unhooked them unless we were thru towing and wanted to use the truck.
