Old 09-15-2016, 01:31 PM   #11
2007 WildCat 32QBBS
05CrewDually's Avatar
https://www.etrailer.com/Accessories...ese/58117.html
05CrewDually is offline   Reply With Quote
Old 09-17-2016, 03:34 AM   #12
FrankG's Avatar
A couple of things. The ball and coupler were designed to carry the load around the outer portion of the top of the ball, (as your photo's indicate) not the flat top of the ball. The materials used in the Ball and Coupler are high strength steel, as opposed to hardened steels which would be suspect-able to cracking and sudden, unpredictable failure. With that said, the materials used are prone to galling. The only way to stop this is to start with relatively smooth mating surfaces and use a good quality grease. It looks like you have a Blue Ox hitch, use the same grease you are using to grease the hitch pivots with. Wipe the ball off after every use and apply fresh. KEEP THE SAND OUT. You may want to clean up the inside of the coupler to remove any burrs.
Good Luck and Happy Camping
2017 Laredo 325RL
2016 Vengeance 29V Sold
2013 F250SC 4x4 gas
Blue OX W/1500 lb bars - For Sale
2012 Spyder RTL - For Sale
FrankG is offline   Reply With Quote
Old 09-17-2016, 06:25 AM   #13
Oaklevel's Avatar
Balls are weight rated as well I would also try a different ball in addition to the grease. I do see that yours is rated at 20,000.
https://www.etrailer.com/s.aspx?qry=...furl=-pg-Balls
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 09-17-2016, 08:57 AM   #14
Thanks everyone for the tips.
dpowli is offline   Reply With Quote
