Old 09-13-2016, 01:54 PM   #1
Bad coupler?
Hi. I need some travel trailer hitch coupler expertise.I just replaced the 2 5/16 ball on my hitch because the old one was showing wear around the top of the ball. It had been used for two years on my old trailer and since April of this year.
The new Reese ball shows galling around the top edge of the ball. The coupler is labeled 2 5/16 and also shows wear only around the top circumference with zero contact at the top of the coupler. The ball also has no wear on the top.
I did check and the trailer has a good ground through the plug so the galling is not from arcing to ground through the ball.
I will try to post pictures.
Any thoughts or ideas? Thanks
Name:	ImageUploadedByForest River Forums1473792834.204867.jpg
Name:	ImageUploadedByForest River Forums1473792855.251443.jpg
dpowli is offline   Reply With Quote
Old 09-13-2016, 02:22 PM   #2
What's the inside of the trailer coupler socket look like?
Have you ever used grease or dry lube?
Days Camped: '16=46 '17=30 '18=51 '19=10
Old 09-13-2016, 02:29 PM   #3
The top picture is the inside of the coupler. Grease was used. The ball only has 450 miles of towing on it.
Old 09-13-2016, 02:42 PM   #4
B and B's Avatar
I believe some grease is needed. Lots of it.
Old 09-14-2016, 09:13 PM   #5
My new trailer has almost the same mileage with a new 14k rated 2 5/16 hitch ball. I haven't looked at the socket yet but my ball looks exactly like yours on the crown. I've always used synthetic grease since we bought the trailer. I always just assumed it was normal due to the weight of almost 1k on the tongue.
2015 Dodge RAM 1500 Laramie w/ 4 Corner Air Suspension, 3.92 gears, 32 gal fuel tank, integrated brake controller
2016 Coachman Freedom Express Liberty Edition 320 BHDS
rocketman1083 is offline   Reply With Quote
Old 09-14-2016, 09:37 PM   #6
Retired JSO's Avatar
Bad coupler?
That's the same way my ball looks on my Blue Ox hitch. New trailer in March 2016. Grease doesn't seem to help. I plan on changing mine next spring.
Retired JSO is offline   Reply With Quote
Old 09-14-2016, 09:43 PM   #7
Crusadernoob's Avatar
Our ball came on the truck so not sure how many miles or how heavy it towed. I grease it every now and then when it gets dry, no wear yet.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 9
Crusadernoob is offline   Reply With Quote
Old 09-15-2016, 07:19 AM   #8
Thanks for the replies. Guess I will just continue to monitor it for wearing in the coupler. Safe travels to everyone.
Old 09-15-2016, 07:46 AM   #9
Where you see the galling is where you need to put the grease. Looks like normal wear without being lubricated.
Old 09-15-2016, 11:25 AM   #10
Bad coupler?
Thanks Old Coot , changing to white lithium to see if it helps. I was using a generic axle grease.
