Old 04-14-2018, 07:56 AM   #1
Ball
Anyone had a hitch ball loosen up?
ijon is offline   Reply With Quote
Old 04-14-2018, 07:58 AM   #2
Oaklevel's Avatar
If it does it was probably not tight enough in the first place. But to answer your question no.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 04-14-2018, 08:05 AM   #3
I check mine every spring before the first pull. Never had one come loose. Just waiting for this blizzard to leave and spring to arrive.
TheWolfPaq82 is offline   Reply With Quote
Old 04-14-2018, 08:16 AM   #4
Oaklevel's Avatar
Just a thought the ball nut does have a lock washer ??? doesn't ???
1966 Mustang GT
1986 Mustang SVO
Old 04-14-2018, 05:17 PM   #5
I had one loosen.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 04-14-2018, 05:18 PM   #6
Yes.
Old 04-14-2018, 05:20 PM   #7
Put lock tight on it.
Old 04-18-2018, 05:42 AM   #8
shorthorn's Avatar
Yep.. on our equal-i-zer hitch after the 2nd time we towed the old travel trailer... not sure if dealer tightened it enough at setup, or it loosened.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 04-18-2018, 06:30 AM   #9
The "Premium Towing Balls" have a Huge shaft,Lock Washer,Huge Nut,and the shaft is Drilled for a Cotter Pin/Ring! Loctite can also be used! Youroo!!
Old 04-18-2018, 06:45 AM   #10
It is hard to get them tight. Need much more than standard open end or ratchet.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 04-18-2018, 07:00 AM   #11
In the neighborhood of 450 ft lbs as I recall.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 04-18-2018, 07:40 AM   #12
Use neither one of these, take to a Truck Shop and pay them to use the proper Tool which is a Huge Torque Wrench set at the Proper Setting for the Thread Size of the Ball! Pay/Tip the mechanic well and Save yourself from buying a Very expensive Tool that will be used few times! Youroo!!
Old 04-18-2018, 07:42 AM   #13
Flybob's Avatar
Most people do not own the proper torque wrench for this job. Need to find a hitch shop or truck service shop.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
