Old 07-25-2016, 01:51 PM   #1
Ball mount height question
We tow our Apex 288BHS with and Ford Expedition EL however this weekend I need to use our F-250. The WDH is set up for the Expedition. The difference in hitch height looks to be roughly 1.5 inches higher on the F-250. Is this within the acceptable range or do I need to try to adjust hitch height on the ball mount head for the WDH? Thank you in advance for the help.
Mike
Mikemiller69gs is offline   Reply With Quote
Old 07-26-2016, 02:51 PM   #2
thebrakeman's Avatar
You will definitely need to adjust. Rule of thumb is that you need to be within +/- 1 inch of being level. If you are currently level with the Expy, you already know that you will be at least 1.5" high with the F250.
Plus, since the F250 has a much stiffer rear suspension, it will not squat as much. I would not doubt you will be 2.5" tongue-high with the current setup.
WDH shank typically has a universal hole spacing of 1.25". So you should try dropping the head 2 hole-spaces. Hopefully, you have enough room on the shank for that. Otherwise, you'll need to get a shank with more drop.
thebrakeman is offline   Reply With Quote
Old 07-26-2016, 09:46 PM   #3
Thanks for the info
Old 07-28-2016, 09:17 PM   #4
Second question
Do I need to change the angle at all?
Old 07-29-2016, 09:59 AM   #5
There is no way of knowing ahead of time.
Dropping the head 2 spaces is to get you started. You need to do a full setup, including front wheel well measurements, to determine if the head angle is still the right setup for proper weight distribution.
Old 07-29-2016, 10:13 AM   #6
Was the trailer level when hitched to the Expy.
Before doing anything, I would hitch-up to the F250 and evaluate.
325BH is offline   Reply With Quote
Old 07-29-2016, 10:16 AM   #7
Check the installation instructions for your WDH and go through the process as if it were new.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 07-29-2016, 10:28 AM   #8
Yes, hook it up and check for level first.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
mount
