Old 05-04-2015, 05:07 PM   #1
Question Ball Size
Waiting on our Vengence 31v ToyHauler to arrive. Purchased an Equalizer wd hitch but didn't get a ball. What size should I get? I believe a 2 5/16 is what I need but wife wanted me to ask here. Let the fun begin!!!!
woodg63 is offline   Reply With Quote
Old 05-04-2015, 05:25 PM   #2
Ford Idaho's Avatar
Get a 2-5/16" and a 2" bases covered.
Old 05-05-2015, 01:29 PM   #3
thebrakeman's Avatar
Definitely 2-5/16"
You are going to need a very large, thin-wall, socket and a torque-wrench good for over 400ft-lbs (if you are the type that cares about proper torque). But definitely the special socket. If you can't get access to the socket, pay a hitch shop $15 or a dozen donuts. Equal-I-zer tries to sell that special socket, but it's probably the only time you'll ever use it.
If you buy the ball at the hitch shop, they might install it as a courtesy for you.
thebrakeman is offline   Reply With Quote
Old 05-05-2015, 01:55 PM   #4
The important part is make sure the Hitch Head hole for the Threaded part of the Ball is (LARGE) and the shaft of the ball is (LARGE),do NOT use a BUSHING to fit the Hitch to the Ball threads!! Youroo!!
Old 05-05-2015, 02:51 PM   #5
Yeah. Be sure the ball is rated at least a high as the hitch.
Old 05-05-2015, 07:39 PM   #6
Get the ball from Progress. Most shafts are too long for your hitch. What I did was remove the sockets from the hitch head. This opens up the area and then no special thin walled socket is needed. Bought a 1 7/8 3/4 inch socket from Tractor Supply for 8 bucks and used a 40 inch break bar to install the ball. Put all of my 150 lbs 36 inches down the breaker bar to equal 450 ft lbs of torque.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-06-2015, 10:20 AM   #7
lbrjet - I like it!
I had access to the right sockets and a 4-foot, 600ft-lb torque wrench (!) at work. I was actually excited to use the thing! But I like your resourcefulness.
Is there anything to removing/reinstalling the sockets, or just as straightforward as it looks?
Old 05-06-2015, 11:00 AM   #8
offroad's Avatar
I bought the same socket, a 3/4" breaker bar from HF, and some black iron pipe at HD for a cheater. Just need to divide 450 by your weight to get how many feet from the socket you need to stand.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 05-06-2015, 01:42 PM   #9
Nope. Take the bolts out and slide the sockets over a bit. Didn't have to take them all the way off. When done slide them back over to line up the holes and put the bolts back in. They are tight but do move with a little effort.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
