Old 11-25-2014, 09:01 AM   #11
fx2
Turn on Tow/Haul mode. That's how mine works in my '14 Ram 2500 but I do have the integrated brake controller.
2014 Surveyor SC321BHTS
2016 Nissan Titan XD SL4x4 Cummins
fx2 is offline   Reply With Quote
Old 11-30-2014, 04:37 PM   #12
Has anyone every actually checked the amount of amp hours delivered by the tow vehicle to an RV battery bank as it's towed down the road? You guys with the Tri-Metric meters could shed some light on this. My guess would be that it's an insignificant amount.
Ham_Bone is offline   Reply With Quote
Old 11-30-2014, 09:20 PM   #13
camaraderie's Avatar
My guess is that you are right Hambone...a simpler method would be to use a clamp amp meter and take a reading on the charging wire. I'm thinking a lot more folks have those and for those that don't..they are handy for lots of things and relatively cheap.
In any event...there seems to be a general assumption that a couple hours of charging down the road and you are all set to go. No matter how many amps your battery charger or alternator can put out all the way down the wire to your trailer batteries.... it will take a MINIMUM of 4 hours (and likely a LOT longer) to fully recharge a 1/2 depleted battery. Minimally charging a battery...then depleting it below 50% is the quickest way to early battery death. No matter WHAT the voltmeter says after you've been driving down the road a while... you aren't fully charged if you haven't driven at least 4 hours because you are reading surface charge not the real state of charge.
Here's a decent & wll priced clamp meter for those interested:
http://www.amazon.com/Auto-ranging-D.../dp/B001VGND88
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 12-02-2014, 03:24 PM   #14
Originally Posted by gljurczyk View Post
Placeholder...disregard..
Hey GLJ...cannnot respond to your pm to me just a while ago...your mail box is full. Clean it up a bit and let me know when I can respond!
________
Cam
Old 12-02-2014, 04:33 PM   #15
Witch Doctor's Avatar
I cleaned it, now you can send me your answer, thanks glenn
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-02-2014, 07:32 PM   #16
Rivnut
Rivnut's Avatar
By all means go to E-trailer and copy down their trailer wiring schematics, I believe there are about 6 diagrams, its's a piece of gold to carry with you...!!
Rivnut is offline   Reply With Quote
battery, towing
