Old 11-24-2014, 04:55 PM   #1
LandJ's Avatar
Battery charge while towing
Does anyone know if I have to do anything to a 2014 Ram 1500 in order to charge camper battery while hitched? I read somewhere that I might need to add a fuse or something.
I don't have the factory brake controller, I bought the wiring harness and used a Tekonsha that I had.
Thanks in advance.
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
LandJ is offline   Reply With Quote
Old 11-24-2014, 05:08 PM   #2
Witch Doctor's Avatar
Maybe they left the fuse out to the pigtail for some reason in your truck. You can just use a multi meter and check your male plug end at the TV. I know on my ford I have a fuse for running lights and another for tail lights. Your break controller also has to be fused in your panel. Just a guess I have a good truck Fix or repair daily.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-24-2014, 05:11 PM   #3
Boss Hoss's Avatar
Check your manual for the fuse location-I'm sure you have one.My F-150 had a fuse location-but no fuse.It's a cheap fix-less than a few bucks for the fuse-but it's good to know that your tow rig is charging the TT battery while your driving.I think it sends the power to the "Brain Box" and that feeds it into the battery.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 11-24-2014, 05:11 PM   #4
Flybob's Avatar
Many TV's have the wiring for the 12V aux in the harness, but do not install the fuse/breaker in the fuse box. You may have to install one. In addition, due to the length of the wire run and the gauge of the wire on most vehicles, you will not have a very high charging capacity. If you are trying to charge a battery that is 40% depleted, the voltage at the battery will not be sufficient to accomplish a good charge, If you are installing things and want to charge the TT battery from the TV, add a larger gauge wire.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-24-2014, 05:56 PM   #5
Most trailer plugs have a charge wire and whether it is hot or not depends on the vehicle. If yours is hot, it will take several hours of driving to charge it if it is down to 40% charge. Most regular battery chargers only have 16 ga charge wires, at least the 3 Schumacher chargers I have are all 16 ga with clips.
Old 11-24-2014, 06:01 PM   #6
Evo2700's Avatar
I had a Tekonsha installed on my Ram which was pre-wired from the factory and it does charge the batteries while hooked up and the truck is running.
2015 Evo 2700
2017 Ram 2500 6.4 Hemi 4.10
Evo2700 is offline   Reply With Quote
Old 11-24-2014, 06:02 PM   #7
Flybob's Avatar
Yes your battery charger may have 16g wire, but it is at most 3 ft long. The wire in your TV /TT setup is probably closer to 20ft plus a plug and a few feet to the battery. At 10 amps and a 0.2ohm charge wire resistance, the 14.8 V from the TV alternator is now only 12.8V
TST Tire Monitors
2 100W solar panels
Old 11-24-2014, 06:15 PM   #8
Well, after having numerous tow vehicles since I started towing rv trailers in 1975, I've never had a problem charging the batteries with the wire in the plug and they sure are not heavier than 14 ga at most and most are just 18 ga. Look at your tail lights, brake light wiring on your vehicle where the trailer pigtail is hooked to.
Old 11-24-2014, 08:42 PM   #9
Stormrider151's Avatar
When I bought my 2012 F150 new there were two fuses in the glove compartment that had to be installed in the high power fuse box under the hood. The hot wire was dead until they were installed. When checking to see if your hot wire in functioning be sure and check it with your truck running. And then with it shut down. This will tell you whether you need to unplug your trailer from your TV when parked and hooked up. If the wire remains hot when not running it could leave with a dead TV battery. Good luck.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 11-24-2014, 09:37 PM   #10
B and B's Avatar
Initially the voltage drop would be higher but as the battery gets charged it would decrease and eventually 13.8 volts would be at your battery.
25 feet of 16 gauge
30 amps charge rate is a 3 volts drop
15 amps charge rate is a 1.5 volt drop
7.5 amps charge rate is .75 volt drop
Trickle charge at 2 amps would be .2 drop of Charging at 13.6 vdc
You are not going to boil the battery dry with too much charge current.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
battery, towing
