12-18-2018, 01:53 PM
Beef up my Duramax
Ok so I have a Chevy 2500 Duramax to pull our Coachman. Friends tell me there is a way to “beef up my Duramax” to get more power out of it? I know that it is in there but don’t know what I need to bring it out? Is there anyone who can help with this? Thank you, Merry Christmas and let’s get to camping!
12-18-2018, 02:10 PM
A tuner and larger exhaust are the ways that most guys start to get more power out of their Duramax engines.
There is a whole aftermarket for Diesel trucks and the Duramax is one of the best.
Start at one of the forums for Duramax trucks.
Duramaxforum.com is an example. There are others.
12-18-2018, 03:04 PM
The gain is usually not worth the price. If you live in a state that does smog checks a tuner probably won't pass. Save your money for fuel...you've got a great motor already.
Before CA started it's diesel smog program I did it all. Tuner, 4" exhaust, straight piped, egr delete, etc. Yes I got more power, 1 or 2 mpg extra but it would take years to pay for itself. How much power do you really need?
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
12-18-2018, 04:28 PM
You can add a stealth Module and keep all your emissions intact if need be. DOnt know what year your truck is, You might not even have stuff to delete anyway..L
12-18-2018, 07:52 PM
I deleted the emissions on my Duramax, I got more power plus better fuel mileage. Plus I don’t have to buy any more DEF, $1400 bucks. The county I live in doesn’t do smog tests so I don’t have a problem with the truck passing vehicle inspection. The best thing I ever did to my truck
12-18-2018, 08:23 PM
Depending on the year would decide what one would suggest to do. EFI would be the way to go, start adding over 100 HP and your troubles will just begin.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
12-19-2018, 01:37 PM
Curious to know what year Duramax and what model Coachman trailer. Most Duramax engines have plenty of power. Just because the engine rpms increase going up hills doesn't mean you need modifications and add ons.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
12-19-2018, 01:38 PM
X2. Mine has 445 hp out of the box. Plenty for all my towing needs.
Mike & Fay
2013 Rockwood 8289 Diamond with 3.5" lift
2017 GMC 2500HD Duramax
Curt A20 c/w GM Puck system
2021 56 night’s booked
12-19-2018, 01:53 PM
are you saying that your duramax does not have enough power??
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
12-19-2018, 03:14 PM
I am sure my diesel Duramax has plenty of power. But I want more. I know they’re under the hood of the truck and I just need to get them out. I have a 2007 Chevy 2500 Duramax and I’m pulling a 40 foot coachman chaparral trailer. I hope this answers some of the questions that some of you have asked? Now I’m looking for the suggestions I want to do? Thank you in advance!
12-19-2018, 03:56 PM
There is no tune delete available for your 2017 L5P engine anyway.
DMax engines from 2001 thru 2016 can be tuned but not yours.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
12-19-2018, 03:57 PM
look on Duramaxfourm.com. There are MANY threads on that exact subject.
12-19-2018, 04:03 PM
I have the same truck. 2007 Classic Duramax LBZ. Here is what I did to mine. I did them one at a time, as I had $$$, which enabled me to tell what affect each one had.
FASS 95 liftpump and filter system to replace stock fuel filter head which always caused me problems (losing fuel prime). This drastically increased pedal response and improved mpg slightly, more so when towing. No more problems causing me to rebuild stock fuel head over and over. Also increases lifespan of CP3 injector pump by helping it out.
EFI live tuning with PPEI custom tuning with DSP5 SOTF switch. This enables you to switch between 5 different engine/transmission tunes on the fly that increase HP in steps from +30 on #1 to +150 on tune #5. Increased mpg, especially freeway driving. Power increase is unbelievable.
EGR complete delete. No improvement in HP or mpg, but keeps the soot out of the oil and the intake manifold. And no future EGR problems or codes.
PCV system reroute. No longer drips oil into the turbo and makes a mess on the top of the motor.
Replaced stock exhaust with straight 5" pipe from exhaust manifold to rear of truck. Just got this done so don't really know the impact on mileage yet. But it sounds good (slightly more throat than stock, but not loud at all) and seems to have even more pickup.
And no, if you are doing this to save $$$, you most likely will never break even, but that wasn't why I did it. Performance gains make it a true pleasure to drive my truck and towing is just downright fun. The EGR delete was to avoid the expensive eventual replacement and make the motor last longer.
For pre DPF/DEF Duramax trucks like ours, I advise everyone to at least do the liftpump and the tunes. Most bang for the buck.
If you can't do it yourself, find a good diesel performance shop by word of mouth.
Have fun!!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
12-19-2018, 04:08 PM
Duramax engine mod
Just wanted to chim in too Normy41. I pull a Cardinal Estate 3850 gross weight 16500, with my 2014 Chevy 3500. This year I have pulled 20,000 plus miles all over the US. I have pulled all the terrain that I have pulled at highway speeds. Never did I ever have an issue (I can eat the lunch of any bus out there, I have passed them all on grade.) So my advice is the motor will pull your trailer with no problem. Leave the warranty intact and just enjoy the ride.
Changing it up a bit
2017 40 ft Cardinal Estate
2014 SRW Chev Duramax 3500
Titan 50 gal fuel tank
Air Lift 7500 lb bags
12-19-2018, 04:14 PM
No warranty on a 2007 to worry about
12-19-2018, 06:49 PM
You need to be aware that the engine is not the only thing in the drive line. You also have a transmission and differential (and a transfer case if a 4x4) that have a torque rating. Back when I was rebuilding transmissions, the straight skinny from a GM drive line engineer was that the Duramax engine was capable of something like 1000 ft lbs of torque and had been detuned to around 450 ft lbs, the transmission was rated at around 500 ft lbs. Before you go tinkering with tuners etc you need to find out what your trans is rated at. These torque ratings have changed over the years and have been bumped up since I retired from the trans business. With the torque that engine is capable of, it would be very easy to exceed the rating for the rest of the drive line.
Jerry & Sally Martire
Culpeper, VA
2008 FR Flagtstaff 831RLSS
2004 Silverado 2500HD diesel
12-19-2018, 06:50 PM
If you beef up your Duramax, you will have a Freightliner!!! Ain't nuthin' that sucker won't do.........leave it alone, man! You have more than you need. Fire it up, hook it up, and roll. The rest of the pack wishes they were you! LOL
FROG AR-0019-242
12-19-2018, 06:55 PM
I have heard of dealers here in N.C. that let you delete the emissions and still have the warranty. I talked to a shop last year that had a two month wait list to delete the emissions, some were new trucks. I think the emissions is a crock, new Diesel engines are pretty clean without the emissions.
12-19-2018, 07:00 PM
And I think deleting the emissions is a crock. And a total waste of time and money.
FROG AR-0019-242
