Old 12-30-2011, 03:57 PM   #1
Bent hitch and frame
I just returned from a trip to the desert in my 2010 Class C Solera. I carried a dirt bike on the rear hitch. The rig bounced around quite a bit while driving off-road to find a campsite. When I got home I found that the hitch and frame it attached to are bent, leaving the motorcycle sitting at a 15-20 degree angle. I'd be interested to know if this is a common problem and how to fix it. Do I need to reinforce the frame so it doesn't happen again? Do I need a stronger hitch? Would I be better off mounting a hitch to the front end? Thanks for any advice you can offer.
scarlton46 is offline   Reply With Quote
Old 12-30-2011, 08:03 PM   #2
bikendan's Avatar
well, i'm sure your hitch has a weight limit which you probably exceeded.
and it's not designed to take the abuse of such a heavy weight off-road.
if you plan to keep doing this, you should have a welding shop add additional bracing.
but this mod will void the frame warranty, probably.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-02-2012, 12:39 PM   #3
As bikendan mentioned a welding shop could help, but the warranty issue? Can you carry you dirt bike in the back of your pickup?
campdohbrew is offline   Reply With Quote
Old 01-04-2012, 02:27 AM   #4
flyrotor's Avatar
It's a class C Solera - Motorhome,
next option - trailer it, little more inconvenience but maybe better in the long run
flyrotor is offline   Reply With Quote
Old 01-04-2012, 03:49 AM   #5
Triguy's Avatar
Sorry to hear about the bent frame and I wish you the best in getting that sorted out.
If you want an idea for the back of your C, I would avoid most frame mounted systems because of the issues you have already experienced. I am not sure of the specs, but I doubt that a Class C can carry much weight behind the coach.
A nifty idea I saw this summer at a State park we were at was this solution called a swivel-wheel. It fits into a 2" receiver as I recall. I like it because the wheel takes up much of the load. They make one and two-wheel systems. Here's a pic from their site ...
You can also consider carrying it on the front using a receiver mounted carrier.
With either front or back solutions, make sure to check the specs for your coach and receiver and match the carrier and bike weight as appropriate.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 01-04-2012, 05:39 AM   #6
Mountainmanbob's Avatar
Swivelwheel --- 50/50 split of weight
If the tow vehicle is to be a fifth wheel travel trailer, the trailer chassis frame needs to be evaluated for the capability of installing a Class-III or Class-IV receiver. The Chassis frame needs to be able to support the weight of the system plus any added loads. The Swivelwheel-46, Swivelwheel-58, and Swivelwheel-58DW systems will have about a 50/50 split. Installing the Swivelwheel system onto a chassis frame that does not have the capacity to handle said system could result in frame damage, slide-outs that no longer work, gel-coat cracking, etc.
so it looks like
this THING would save on 1/2 the weight
just wondering about the other 1/2
some of the frames around
seem to have problems
with ((no)) extra weight added
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 01-04-2012, 09:44 PM   #7
Thanks for the response. I don't have a pick-up. Just the motorhome.
bent, solera, bent frame
