Old 07-29-2011, 11:16 PM   #51
Kudos for etrailer.com
Thought the members should know the outstanding response I received from Michael Lindsay at etrailer.com. I contacted them about the bent brackets and was upfront that I hadn't purchased the Reese Strait line from them. They were very helpful nevertheless and one of their tech team people followed up with me. Kudos to the guys who get my business next time!
cavponysoldier is offline   Reply With Quote
Old 08-13-2011, 06:06 PM   #52
Look'in To Ecapé's Avatar
Just to clarify...all three times we have had the brackets bend have been in forward motion and we know that it happens when the truck and the trailer are on opposite inclines to each other or in a sharper turn that puts the truck and trailer way off a level plane - such as when pulling out of a parking lot or making a turn out of an incline. Took our first trip out since installing our newly received "reinforced" brackets and arrived home without them bent. However, we are overly cautious about where we go now and go to great lengths to try and not get in the situation that we know bent the previous brackets. Yes, we use the 1200# bars so would be interesting to know if it is these bars that are having more of this issue then the 800# bars.
I'll be interested to see what happens in future trips and will certainly update here on this thread.
Roger & Dawn M.
2011 Rockwood Signature UltraLite 8315BSS
2004 Ford Excursion
Nights camped in 2011: 27
Nights camped in 2012: 34
Look'in To Ecapé is offline   Reply With Quote
Old 08-14-2011, 09:50 AM   #53
MtnGuy's Avatar
1200 lb. bars on a trailer with a listed dry tongue weight of 814 lbs. is probably sized about right. Reese skips from 800 to 1200 lbs. with the trunnion bars, although I think you can get 1000 lb. bars with the round bar system.
It makes sense that the 1200 lb. bars would cause the problem more than 800 lb. bars, since it puts more stress on the system.
Old 08-14-2011, 10:03 AM   #54
Dismember
TimeFurnace's Avatar
I couldn't be happier with etrailer. I go there first when looking for gear. On a recent order, about a day after I placed it, I received a personal phone call from them that part of my order would be delayed from their vendor and they were eager to know how I would like to respond. Most companies would have just kept me waiting. Other than one exception, all other orders from them have arrived faster than expected. They are just great to deal with.
2012 Wildwood 24TBSS
2x80W Solar Panels, Morningstar MPPT Controller, Xantrex LinkLite Battery Monitor, Xantrex ProWatt 2000 Inverter
2010 Toyota Tundra DoubleCab 5.7L 4X4
TimeFurnace is offline   Reply With Quote
Old 08-14-2011, 10:37 AM   #55
leencharlotte's Avatar
I have the 1000lb round bar dual cam setup. I was looking for the installation manuals on their website and could only find 800 /1200#. So I called. They said after further testing they recertified them to 1200#. So the 1000# round bars are now 1200 according to the cd person at Reese
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 08-14-2011, 10:38 AM   #56
MtnGuy's Avatar
I had heard that also, so it is good to get confirmation. Thanks.
Old 08-14-2011, 01:08 PM   #57
Coops1's Avatar
We had our trailer at the dealer fixing a few things and looking at the bent snap bracket and they readjusted the cam arm lengthening it by 3/4" to an 1". I've brought the trailer home and so far the bracket is fine but we head out this week on another trip so we'll see what happens.
One result of this adjustment is how much easier it is to remove the bars off the cam, before I would have the jack up so high almost lifting the truck off the ground and would still have to hit the bars with a hammer to knock them out of the cam.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 08-14-2011, 01:40 PM   #58
MtnGuy's Avatar
Something just ain't right with that. Once you remove the chain from the snap up bracket, there is no tension on the cam and spring bar.
Old 08-14-2011, 02:06 PM   #59
Could be too much tilt on the head so the relaxed position is still pushing down on the cams??
Old 08-14-2011, 02:30 PM   #60
MtnGuy's Avatar
That would really be a tight setup, and probably way too much tilt of the head assembly. My cams will go all of the way to the ground once I release the chains, but I have a low tongue. I would guess if once the chains are off and the cam rotated to downward position the spring bars still won't come off, then the entire setup needs to be reviewed. If you need a hammer to get the spring bars off, how in the world do you get them on ??
bent
