08-18-2015, 01:08 PM
#21
I pull with a SWB GMC 2500HD using a SuperGlide hitch and MorRyde pin box. No chucking, and SuperGlide is flawless turning 90 degrees, forward or backward, without having to give thought to the angle. All automatic, mechanical, no electronics.
If I had to buy new, would do exactly the same thing. Regardless of your brand selection, highly recommend getting an automatic slider if you have a short bed. When you need it, you need it.
08-18-2015, 01:16 PM
#22
Originally Posted by pontiacdan45
We have a 2015 32 foot Rockwood fifth wheel with a Reese revolution hitch and pin box and tow it with a GMC 2500HD with the short box.
This hitch setup uses a wedge to eliminate the trailer from rotating from the hitch and shifts the rotation point to where the pin box attaches to the trailer. You can do tight turns without worry.
The downside is that hitching and unhitching can be difficult at first until you understand the process. Once you get the hang of it, easy as pie.
X2
You should also check out OldCoot's pictures. Hopefully he will also post a reply. He has a cover on the truck that he can use while he is towing. Sounds like you have a similar cover. He also has a way to stop any "chucking".
08-18-2015, 01:45 PM
#23
Toadman
We have a B&W companion hitch in our 2008 Chevy 2500HD. This hitch uses the existing B&W gooseneck turnover ball type hitch that was already installed in our truck when purchased. The companion hitch is an add-on that B&W created to use. The beauty of these hitches is that in about 5 minutes I can have a completely clean truck bed after I remove the hitch and hardware. No rails to deal with and it pulls like a dream. I also have the AirRide suspension add-on that is made by TrailAir and that also makes a huge difference.
08-18-2015, 03:12 PM
#24
I also vouch for the B&W companion with the turnover ball hitch!
08-18-2015, 03:58 PM
#25
You will find hitches that will do what your needs are. I use the Superglide hitch with the Morryde pin. We just came back from 2700 mile trip in Colorado mountains. Many of the RV spots were tight. We made a lot of 90 degree turns to get into some of the spots. I also have a short bed truck, Chucking is something if you do not get right, you will soon after. It feels like jumping back and forth to me. I have none of this feeling now.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
08-18-2015, 04:06 PM
#26
Me too! Companion 3500. No noise, and when removed, bed is empty.
Only draw back is, it is heavy.
David & Kelly
2015 Sandpiper 355RE
2015 Silverado 3500 CCSB SRW 4X4 D-maxx
Nights camped in 2016:03😄
08-18-2015, 04:24 PM
#27
I've heard great things about the Anderson hitches, but no personal experience. I had a Reese Goosebox installed on my Silverback 29RE, and a B&W turnoverball installed in my F250 SD 6.5' bed. The Goose Box replaces the stock pinbox, and uses the Fifth Airborne technology with a dual shock absorber and an airbag. It pulls nicely, with almost zero chucking and jerking. Highway bumps are rarely felt in the truck, and are much softer than anything I've driven before.
After putting the RV up, I flip the ball and my truck bed becomes flat again.
I really liked how the B&W companion was built, but when not towing, you have to lift that heavy thing in and out. Not a problem when I was 30 or 40, or even 50. It becomes a problem at 62.
I just didn't want to be lifting a hitch in and out of my truck bed. Another benefit (even over the Anderson) is that when I'm hitched to the 5er, I have a lot more free space in the truck bed. Just an observation.
Finally, let me say this. You are doing yourself a huge favor by asking this question and getting input from other 5er owners. Because there are hitches out there that will make your towing experience a miserable one. Trust me on this,....I've been there. Drive a chucking/jerking heavy 5er down Interstate 10 between New Orleans and Baton Rouge. You'll swear that the trailer is about to rip loose and go flying across the highway median.
I highly recommend the Goosebox/turnover ball hitch setup.
Good luck
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
08-18-2015, 04:31 PM
#28
Another vote for the B&W Companion hitch.
I have a small chain hoist that would pick it out of the bed with no problems, I would build another dolly to move it around when not in the 250.
Like so.
08-18-2015, 04:36 PM
#29
Reese Elite 18 k with Pucks. Clear bed, perfect Wedge fit with my Reese Revolution. Works great and the big jaw surrounds the back of the pin, secure system.
B and B
08-18-2015, 04:59 PM
#30
Hitches and Couch
Originally Posted by BandJCarm
I want this deal to be our last. I want to NOT make any mistakes. Wife wants this and that and the other options in the TT..........but I want to ensure I can pull this thing across America, back it, and be happy. TV is a 2015 Chevy 2500 Duramax with 6.5' bed. (I also have the Bak Flip F1 cover, and am hoping it will fold out of the way ok).
I would appreciate all comments. We are in Arkansas, but possibly going to Couch in Hamilton OH first of September to view their stuff (any comment on that dealer is welcome also!!!).........on our way to STL to see a few Cardinal games.
Thoughts?????
I didn't have the Chev Duramax, had a short bed F350 instead with Reese 15K Pro slider. This setup worked really well with my 30' Sundance with 2100 lb. pin weight. DW hated the metal on metal screech when sliding the hitch back but keeps from putting camper hickies on your cab. The 15K Pro was too light when we upgraded to a larger fiver so went with the Reese Elite 18K which drops in to Ford truck beds. Our larger fifth wheel also has a Trailair pin box which makes for a very comfortable ride in the truck.
I had a 3 fold Bak FLip on the short bed Ford 350 which worked well with the Sundance but the Trailair hitch interfered with the Bak Flip when 2 sections were down. Sold it and got a Retrax sliding cover and never looked back, best investment I ever made.
We live 45 minutes from Couch RV and can tell you they move a lot of products through that dealership. The majority of what they sell goes out of state so be sure your local dealer will honor warranty on an RV purchased somewhere else. My brother-in-law bought a Wildcat from them and it was an easy and pleasant transaction but he never went back for warranty work.
When we were in the market for a fifth wheel we looked at Couch several times at their location and RV shows. We never found what we were looking for so ended up purchasing at Holman RV which is located about 20 minutes from home. Holman has serviced two of my fifth wheel RV's and while it takes some time to get in line the service work has been top notch.
There's a lot to be said for having a local dealer that can/will service his customers. If you decide to visit Holman while in the area let me know and I can provide you with a good contact.
Good luck!
Nick, Sharon and Finnigan
08-18-2015, 06:05 PM
#31
My truck already had the B&W turnover ball setup so I did the opposite of most and went with the Reese Goosebox. It replaces the stock pinbox. It has suspension in it for a smooth, noise free ride. It is also only approved gooseneck setup by Lippert as Far as factory warranty goes. If you truck has a ball then this is the easiest way to go. It is good for up to 16k units.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
08-18-2015, 06:31 PM
#32
Originally Posted by muddyrode
I would look at going with a sidewinder i have a older 3300 pullrite and have hit my sides with the hitch in turns on unlevel ground if i went with the hitch lift kit my trailer would not sit level and i,m not alone on this i have a friend with anewer 2015 2500 who has the hitch lift as he is afraid of hitting and his trailer sits high in the front and was talking to a guy at goshen that has the sam problem and he did buy and try the lift on his hitch but the same traler sat high in front he said he waisted 150 on the lift and his truck was tore up worst than mine looking at converting to a sidewinder jmo
I was unable to make heads or tails of this post. Punctuation and capitalization would help! Like a lot.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
08-18-2015, 08:16 PM
#33
Good points Doc.
Reese also makes a 20,000 lb Goose Box.
08-18-2015, 11:23 PM
#34
Jeffco, MO
Check our signature. We love our new TV and RV. Started with a couple of TT and one 5er. Now have one we both agree will be with us for longer than 3 years.
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
08-19-2015, 12:15 AM
#35
I would recommend the Hensley BD3
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
08-19-2015, 07:55 AM
#36
How much does that beast weigh?
Sent from my SM-N910V
08-19-2015, 08:02 AM
#37
Mustard, that's the first question I thought of as well. One would either leave it in the truck all the time or rig up an overhead winch.
08-19-2015, 10:05 AM
#38
It weighs 300 lbs
Scott & Vicki
2021 4 reserved
08-19-2015, 12:27 PM
#39
And the winner is..............
B&W Companion Slider, with Trailair Tri-Glide Pin Box.
(I think. After talking to dealer today, may NEVER be able to afford the camper any danged way!!! )
08-19-2015, 02:03 PM
#40
You should check out the B&W Companion hitch
