Old 08-18-2015, 06:05 PM   #31
My truck already had the B&W turnover ball setup so I did the opposite of most and went with the Reese Goosebox. It replaces the stock pinbox. It has suspension in it for a smooth, noise free ride. It is also only approved gooseneck setup by Lippert as Far as factory warranty goes. If you truck has a ball then this is the easiest way to go. It is good for up to 16k units.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 08-18-2015, 06:31 PM   #32
lesptr's Avatar
Originally Posted by muddyrode View Post
I would look at going with a sidewinder i have a older 3300 pullrite and have hit my sides with the hitch in turns on unlevel ground if i went with the hitch lift kit my trailer would not sit level and i,m not alone on this i have a friend with anewer 2015 2500 who has the hitch lift as he is afraid of hitting and his trailer sits high in the front and was talking to a guy at goshen that has the sam problem and he did buy and try the lift on his hitch but the same traler sat high in front he said he waisted 150 on the lift and his truck was tore up worst than mine looking at converting to a sidewinder jmo
I was unable to make heads or tails of this post. Punctuation and capitalization would help! Like a lot.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 08-18-2015, 08:16 PM   #33
Good points Doc.
Reese also makes a 20,000 lb Goose Box.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 08-18-2015, 11:23 PM   #34
Jeffco, MO
tedstr's Avatar
Check our signature. We love our new TV and RV. Started with a couple of TT and one 5er. Now have one we both agree will be with us for longer than 3 years.
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
tedstr is offline   Reply With Quote
Old 08-19-2015, 12:15 AM   #35
SYE
SYE's Avatar
I would recommend the Hensley BD3
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 08-19-2015, 07:55 AM   #36
How much does that beast weigh?
Sent from my SM-N910V
mustardbucket107 is offline   Reply With Quote
Old 08-19-2015, 08:02 AM   #37
Mustard, that's the first question I thought of as well. One would either leave it in the truck all the time or rig up an overhead winch.
Old 08-19-2015, 10:05 AM   #38
SYE
SYE's Avatar
It weighs 300 lbs
Scott & Vicki
Old 08-19-2015, 12:27 PM   #39
BandJCarm's Avatar
And the winner is..............
B&W Companion Slider, with Trailair Tri-Glide Pin Box.
(I think. After talking to dealer today, may NEVER be able to afford the camper any danged way!!! )
BandJCarm is offline   Reply With Quote
Old 08-19-2015, 02:03 PM   #40
You should check out the B&W Companion hitch
hollandti is offline   Reply With Quote
5er, hitch
