Old 06-15-2015, 07:59 AM   #1
avolnek's Avatar
Best 5th wheel hitches
Hey all, i'm certain this is one of those overly repeated threads but in my searches didn't find what I was really looking for.
I am currently driving a 2015 ram 2500 crew cab short box without the factory 5er prep.
Has anyone installed rails into a 4th gen ram? any suggestions?
Next question is what would you guys suggest for a fifth wheel hitch for the crew cab short box? a 16K hitch would be plenty for our needs.
I am sort of eyeing the curt manual slider, more or less just in case...
Thanks,
Alex
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 06-15-2015, 08:06 AM   #2
mcnabbwr's Avatar
I can't help with the install but take a look at the Husky hitch. Very high quality and solid.
Husky Towing
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 06-15-2015, 08:14 AM   #3
Taranwanderer's Avatar
4th gen 2500 Ram here. Went with the B&W Turnover Ball and their Companion 5th wheel hitch. Totally removable when not in use, returns your bed to completely flat when you take it out. The older model was rated for 16k, but the new one is rated for 20k. They even have a sliding Companion now.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-15-2015, 08:53 AM   #4
jtstromsburg's Avatar
This ^^ in my opinion, best setup on the market. On my second one currently. The first did its job in a rollover accident last winter. Thankfully, the companion hitch is engineered to give way in the event of a rollover, and only then. My truck, with my wife and three young daughters, would have been pulled over along with our fiver had it not given way.
I love having the completely empty bed when needed as well. Just Saturday morning I pulled the hitch out. Took all of three minutes and it comes apart in two pieces so I was able to set it on the floor of my garage on my own.
Joel
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 06-15-2015, 12:31 PM   #5
Fulltime family RVer
X2 - love my B&W Turnoverball and Companion. A little spendy, but great hitch.
ependydad is online now   Reply With Quote
Old 06-15-2015, 12:54 PM   #6
Rodney & Patty
some advice
I have installed fifth wheel hitched in 2 4th gen Rams - the installs aren't bad. Both I did alone in about 2 hours each. There are many options out there but if you are going with a universal rail system, which I use, I recommend Curt brand - they are the exact same mounts as some of the others out there but are generally 15-25% cheaper to acquire. They have custom bracket kits that take out all need for modifications and guess work. I have a Reese 15k Pro fifth wheel and also a 20k goose neck ball on a plate that fits into the universal rails.
For the last year or so I have been considering upgrading my hitch to a double jaw rather than the slide bar type that I have, but what I have works well, just got back from a 1100 mile trek last night with no issues - even through the Pennsylvania mountains and the I95 traffic. Some out there today have rubber torsion blocks to absorb some of the highway bounce that you can get, especially in construction zones and I think that may be a plus. Generally speaking, a very nice hitch is far less expensive than upgrading your pin box.
rdenslow is offline   Reply With Quote
Old 06-15-2015, 01:02 PM   #7
I love my Companion. Easy to put on & take off and simple to operate. A really high quality rig: plenty of steel and nice jaws.
Waynedeer is offline   Reply With Quote
Old 06-15-2015, 01:03 PM   #8
Travler's Avatar
Another one for the turnover ball from B&W. Love mine. Works great. I think the ratings are 18k on older ones. The 16k units are the ones with rales.
Travler is offline   Reply With Quote
Old 06-15-2015, 01:41 PM   #9
Frame brackets should be available to mount the rails.
PullMor makes a nice automatic slider which solves the short bed interference issue.
Etrailer should have it all.
Harkerr is offline   Reply With Quote
Old 06-15-2015, 01:53 PM   #10
my 2014 RAM 2500 came with the 5 mount wholes in the box already. The mount frame is a easy removed by to levers on the frame. Reese also makes the frame that drops in the 4 fifth wheel mounts in the box of the truck. I have a 16K Husky hitch that fit the dodge frame in the box perfectly. Have had no problems with my slider.
b1hasj83 is offline   Reply With Quote
5th wheel, hitch, wheel
