Old 05-26-2015, 01:31 PM   #1
nexcompac's Avatar
Best family TV for bumper pulling
Needing some advice.
Currently we pull a Toy Hauler and the TV is a Dodge Ram 1500. The engine is strong enough and the trans is rated to pull the thing, however the rear coil springs do not help hold the weight. We have a 12 lb Equal-i-zer hitch which does help and we have placed airbags in the springs to also help the load. The biggest issue is not the 7 m/g, rather the space inside the truck!
We are a family of six. Which means the crew cab is loaded! Right now the kids are still small, oldest is 11, so they still fight over who gets to sit up front. The biggest fight is who does not want to sit back middle....
As they get older and taller, i know that will only get worse! So... I need some advice on what to buy.
I was looking at getting diesel Excursion which sits 8. That way we have benches to sleep on after a long day/week riding dirt bikes and camping. I know the 7.3 is better than the 6. But what else is there? I know we can also get a big ol' gasser burb, but that gets 10 m/g, 12 on good days. And thats not towing. We need something thats a bit more practical... if possible.
Im open to suggestions!
Thanks in advance all.
Just to be clear... no I dont want to transport two vehicals AKA truck and small car.
26' Forrest Sierra Toy Hauler
26FBSP
Pulling toys for my boys!
nexcompac is offline   Reply With Quote
Old 05-26-2015, 04:33 PM   #2
MtnGuy's Avatar
IMHO, the Excursion is gonna be your best bet. With the tongue weight of the toy hauler, 6 passengers (and gear), you are going to probably be over the GVWR of a regular 1/2 ton based SUV. A Burb 2500 or a 3/4 passenger van might work, also.
Having to use a 12,000 lb. Equal-i-zer, what is your tongue weight ?? Hitch capacity may be a problem on 1/2 ton SUVs, also.
Old 05-26-2015, 04:56 PM   #3
nexcompac's Avatar
The TT Max weight is 11400. The equalizer max trailer is 12k but tongue max is 1,200.
26FBSP
Old 05-27-2015, 12:53 AM   #4
Tonkatoy77's Avatar
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 05-27-2015, 11:56 AM   #5
mike.t's Avatar
Tongue weight should be 10% of trailer weight. So it looks OK.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-27-2015, 12:24 PM   #6
MtnGuy's Avatar
If the trailer tongue is indeed in the 1200 lb. area, that is going to be a major factor in the type of vehicle you buy.
Putting 1200 lbs. on the bumper, and another 600 lbs (guesstimate) in passengers, that that is in the 1800 lb. range. I doubt there are any 1/2 ton SUVs that have a "true" payload of 1800 lbs. The actual payloads stated in brochures tend to fall a bit short, by the time options are added.
Many 1/2 ton SUVs are not made to pull that kinda that weight, meaning the hitch may not be up to the task.
The GCWR may also be a problem. When maximizing the load in any vehicle, the trailer weight needs to go down to stay within the GCWR guidelines.
Granted, the maximum weight on the trailer may not be at the 11,400 lb. limit. A weigh in at a CAT scale (or other facility) can give you the figures needed to make your next choice of vehicle.
Old 05-27-2015, 01:32 PM   #7
Had to read this post -- didn't realize TV stood for tow vehicle!! :-)
Dick Lewis
2015 Forester 2501 TS
Toad: 2013 Honda CRV
Doxies Penny & Lucy
Located Western States
ustamiata is offline   Reply With Quote
Old 05-27-2015, 01:41 PM   #8
mike.t's Avatar
I was going to reply once on a topic like this until i figured out that antenna was not quite what they were looking for.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-27-2015, 02:02 PM   #9
Cathcartww's Avatar
That is a big trailer for anything but a big pick up. You will look hard and long for a SUV rated for over 10,000 lb and 1,000 hitch weight - a few out there, but few and far between. Your best bet might be to find one ton passenger or conversion van with a huge gasser or diesel engine - it is not unusual to find these rated 10000/1000, then upgrading the OEM hitch and rear springs. I have heard it can be done to get 12000/1200, but have not done it myself .....
Cathcartww is offline   Reply With Quote
Old 05-27-2015, 02:11 PM   #10
mike.t's Avatar
Ram 2500 comes with a class V hitch 17500 tow 1800 tongue weight.
2015 Salem 27RKSS
55' Chevy Bel-Air
