Old 08-04-2014, 09:44 PM   #11
asquared's Avatar
For just a little more get the ram 3500 with the 6.4. It will give you the cargo capacity and power for your next trailer when you get a case of two footitis or keeping up with the Jones.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 08-05-2014, 11:04 AM   #12
thebrakeman's Avatar
The hp and torque numbers aren't much different between these 2 engines (only about +20 on each). I didn't look up the torque curves, but I would guess the 6.4L gets to peak torque MUCH sooner than the 5.7L. Otherwise, I don't see the point.
thebrakeman is offline   Reply With Quote
Old 08-06-2014, 05:52 AM   #13
indybp57's Avatar
The point is that "6.4L HEMI" on the side of your truck looks more bad a__ than "5.7L HEMI".
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 08-06-2014, 07:02 AM   #14
FlCummins's Avatar
Originally Posted by sellis1053 View Post
I have narrowed my search down to two Ram 2500's. One has the 5.7 hemi with the 4.10 rear end. The other is the 6.4 hemi with the 3.73 rear end. Any thoughts/comparisons between the two for general driving and towing a 7,000 pound travel trailer would be greatly appreciated.
If you're only pulling a 7,000 lbs trailer why not consider a 1/2 ton truck? That should save you money as well. Either of those trucks are more than you need. However, if I was going to spend the money I'd get a diesel. The resale value of diesels especially here in Florida is astronomical! A 3500 diesel that is 1o years old with only 60-70k miles will command far more than the Hemi with similar miles. My daily driver 06 3500 diesel dually gets 18 mpg around town and 12 towing a 12,000 fifth wheel.
2006 Dodge Ram 3500 Dually Cummins 5.9 Diesel
FlCummins is offline   Reply With Quote
Old 08-06-2014, 07:25 AM   #15
Two reasons. I have a 1/2 ton now and am up against the payload capacity fully loaded ready to travel. Second, you never know, I may get a bigger/heavier camper in the future. Thanks though.
sellis1053 is offline   Reply With Quote
Old 08-06-2014, 07:32 AM   #16
Salt Shaker's Avatar
Neither will be a gas sipper. The maintainance on the 6.4 will be slightly more as it is full synthetic. The 6.4 is a wicked motor. You are right about short trips in a diesel without bringing them up to temp.
I am seriously looking at the 6.4 right now to replace my 6.7. It sits 90% of the time hooked up to a boat. The cost savings of diesel is just not there any longer (thanks to the EPA tree hunging commie low sulphur diesel promoting idiots).
I am still waiting to get some real world numbers on what the 6.4 gets towing. The 5.7 has plenty of grunt but everyone I know that pulls with one is getting 6-7 mpg. I put 120k on a hemi charger and I thrashed it. It ran like a clock without a single issue.
Personally, I would go down and order one and get exactly what you want. Scan you build and email 3 different dealers and see what kind of prices you end up with. 1% off invoice should be an easy find.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 08-06-2014, 07:42 AM   #17
I just went from a 5.7 1500 to a 6.4 2500 for the same reasons as you. I just took the first trip towing with it this past weekend and I really like the 6.4. It get a little better gas mileage than the 5.7 (close to 10mpg compared to 9mpg) probably because it is not working as hard. Not that either have to work hard for what I pull. The heavier suspension is what I really enjoyed. My 1500 would have a lot of bounce when towing even though I had air bags. The 2500 has none of that. The ride is very smooth which makes the wife much happier.
grubbster is offline   Reply With Quote
Old 08-06-2014, 07:57 AM   #18
I have a 2014 Ram 2500 with the 5.7. I pull a 30' TT that comes in just under 8K lbs. and it does a fine job. I live in flat land here is NW Ohio. I took a trip to Jackson, Mi just north of MIS and pulled over 11 mpg hand calculated. I kept the speed around 60 mph. I also drive 50 miles a day for work and average around 16.5 mpg unloaded. I hear the 6.4 is a beast but the 5.7 is no slouch. Either way you go I think you will be satisfied. I came out of a 2009 Ram 1500 Hemi and it is much more enjoyable pulling with the 2500. Good luck with your search!
2014 Coachmen Catalina 303KDS
Miller303KDS is offline   Reply With Quote
Old 08-06-2014, 08:20 AM   #19
Old 08-06-2014, 09:08 AM   #20
What rear end did you go with and how heavy is your trailer?
towing
