Old 03-02-2019, 01:26 PM   #1
Best Gear Ratio?
I am shopping for an upgraded tow vehicle. Three gear ratios are offered. 3.21, 3.55, and 3.92. I would be towing a 27' Forest River Surveyor. Do I need the 3.92 or is 3.55 OK?
Btsanders101 is offline   Reply With Quote
Old 03-02-2019, 01:46 PM   #2
Without knowing the engine and transmission I’m going to say 3.92.
Nascon is offline   Reply With Quote
Old 03-02-2019, 01:50 PM   #3
Multi-Slacker
Assuming the engine can handle it, 3.55 might be OK on the flats while 3.92 (or higher) will be needed for western mountains. I have 4:10s in my 2500 Chevy.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is offline   Reply With Quote
Old 03-02-2019, 01:52 PM   #4
Chuck_S's Avatar
You going to be towing it every day? If not the ratio makes no difference.
3.73 axles on my '07 Ford 5.4V8 towed no better then the 3.31 axles on my '17 3.5EcoBoost. With a good engine torque curve the axle ratio matters little.
-- Chuck
Chuck_S is online now   Reply With Quote
Old 03-02-2019, 01:58 PM   #5
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Add to the confusion....GM and Ford are about to release new 10 speed transmissions to the heavier trucks. Do not know how many overdrive gears will be in them, so homework will have to be done what rear gear ratio will be best!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 03-02-2019, 02:03 PM   #6
Broken Toe
Cowracer's Avatar
As a general rule of thumb...
The only time you will regret having too short (numerically larger) of gears is at the fuel pump. You will regret too tall (numerically smaller) gears all the rest of the time.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
Old 03-02-2019, 02:17 PM   #7
Scoundrel
HangDiver's Avatar
For a Dodge Ram 1500 you'll likely get a higher towing capacity with a 3.92 rear axle.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 03-02-2019, 02:42 PM   #8
nomad297's Avatar
4.10:1 or nuthin’
But I don’t really know.
Bruce
Old 03-02-2019, 03:14 PM   #9
Check the towing capacities of the vehicle. Yours trailer could be #7,000.
Most new trucks have transmissions with more gears. Usually a lower first gear. Many automatic transmissions start the car in second as a result. My new Jaguar does.
Older trucks had a four speed with a non synchro granny low you used to pull for ultimate power and nothing else. Sort of the same deal.
The rear number a fixed gear ratio. The higher the poorer the mileage every day. A little faster. Runs at higher rpm on the highway.
If your pulling boats out of water go big. Otherwise I would go with the truck stats.
tomkatb is online now   Reply With Quote
Old 03-02-2019, 03:29 PM   #10
Grammar Pedant
67L48's Avatar
Don't know the truck platform, engine, weight of the trailer, where he's towing, or anything else. So, I'm going with 8. My answer is 8.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
