Old 08-21-2015, 05:51 PM   #1
gashog's Avatar
Best Locking Receiver Hitch Pin
Looking to get a Locking Hitch Pin. I have no experience with these locking ones. Which one is the best? I want one that when it's locked you don't have to worry that it didn't lock and might come off. In short, I want one that's the best and 100% idiot proof...
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 08-21-2015, 05:57 PM   #2
Check out the BOLT locks on Amazon, it will use your truck key.
I hate it when I think I'm buying
ORGANIC VEGETABLES
But when I get home
I discover they're just
REGULAR DONUTS !!!!!
coffeebean43140 is offline   Reply With Quote
Old 08-21-2015, 06:52 PM   #3
Who Dares, Wins
doc73's Avatar
I used a reese for awhile. It worked until I went to remove it... Seized on there. Had to grind it off. I now have a Master Lock brand class 5 pin. I works well and it is either on or off.. The lock is about the size of a small padlock base so it can be a pain to work around it when hooking up the safety chain hooks. I only leave it on when the WD head is in (I do not want to grind this one off either). I just spray the inside with WD-40 to keep it happy.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 08-21-2015, 07:06 PM   #4
^^X2
Bolt is the best IMO. It save me having an extra key AND if you store your trailer away from home it insures you will have the key when you go to pick up the trailer
EDIT: I formerly had a Reese and never really had a problem with it except the extra key. In any case, the only drawback I know about any of these is if your truck has any obstructions like the trailer light cable connection very near the hitch. I always make sure to put the lock side away from the obstruction so the key is easy to get in.
madmaxmutt is offline   Reply With Quote
Old 08-22-2015, 12:03 PM   #5
BooBoo23's Avatar
Get a lock with a rubber boot on it to keep out the crud and also put some dry lube on it to prevent (reduce) rust.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 08-22-2015, 12:15 PM   #6
peaceparson
that's no the only thing that stays happy with a shot of wd40! I use it on the hitchball, crank-down stabilizers, and anything else that is metal and is designed to move. Keeps me happy as well, when things slip and slide easily into place.
peaceparson is offline   Reply With Quote
Old 08-22-2015, 03:42 PM   #7
gashog's Avatar
I also use WD40 to remove the adhesive left over from when I removed all those idiot and product advertizing labels on the outside of my TT
back to the receiver lock. I do not want one that has the bent pin. The bent portion works it was to the receiver and it's making the 5/8 hole in receiver look like a egg.
I'm think the Master Lock/Extended might be the one, Anyone using this one?
http://www.autozone.com/trailer-hitc...ck/164251_0_0/
Old 08-22-2015, 04:14 PM   #8
Who Dares, Wins
doc73's Avatar
Master Lock/Extended length receiver lock 1469DAT at AutoZone.com
Hmmm.. Off topic again but my one side has a slight egg shape. I wondered why, now I know... And knowing is half the battle!
Thanks!
2015 Chevy HD D-Max
Old 08-22-2015, 04:21 PM   #9
Jimandchris's Avatar
Yep, been using that one for both the boat and the tt wdh. Still works great after 4 years of use....
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 08-22-2015, 04:31 PM   #10
gashog's Avatar
Thanks, but I have a question on it. When you put the locking mechanism on the pin, is it a positive on where you don't worry that it might fall off while towing?
Old 08-22-2015, 04:31 PM   #11
Just use a 5/8" gr 5 or 8 bolt and lock nut. If you have carbide drill bits, drill the end and install a padlock.
Old 08-22-2015, 04:34 PM   #12
Who Dares, Wins
doc73's Avatar
Not smart enough to know.. But no chance of a side load / rocking of the bolt pulling the lock out if it is drilled? I am guessing the forces are just front to back?
2015 Chevy HD D-Max
Old 08-22-2015, 04:39 PM   #13
If you use a 5/8" bolt & lock nut, you tighten the nut and install the padlock on the exposed thread portion.
Old 08-22-2015, 04:40 PM   #14
Yes, the lock portion snaps on securely with a "click". The only dowside of it is that in order to snap the lock portion on, the key must be inserted in the lock at the same time.
Old 08-22-2015, 04:42 PM   #15
Who Dares, Wins
doc73's Avatar
thank you... Looked right past that part, just woke up for night work.. Need my coffee I guess. That seems much better than a seized on there hitch lock that never seams to be rust resident as they say here in the great NE!
Thank!
2015 Chevy HD D-Max
Old 08-22-2015, 04:51 PM   #16
Ham Camper's Avatar
I have the Master lock mentioned above. But have not used it for any distance yet. That will change soon. It seems to be very heavy duty and has the rubber cap covering the keyhole.
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 08-22-2015, 05:03 PM   #17
I think you must be pushing the pin in too far. I have been using the bent pin type for a LOT of years without issue. The vast majority of the force is clearly front/back. The only way it could oval the hole is if it is in too far when the front/back force is applied.
Old 08-22-2015, 05:25 PM   #18
gashog's Avatar
I have .100 of slop between the WDH shank and the receiver on the truck. This constant movement somehow work the pin in and it's wearing the 5/8 hole.... Working on a clamp to hold the shank to prevent any movement in the receiver... Meanwhile I made a bushing with a set screw that I've slid on the pin up the the bent portion of the pin, no more egg shape wear,.
Old 08-22-2015, 05:42 PM   #19
I guess I could see that happening. It sounds like you have a good solution to give you peace of mind. I cannot believe it would ever really be a safety problem, though. I had my last truck for 14 years and it never broke the receiver using a bent pin. Those parts generally are made to deal with the forces that are placed on them.
Old 08-22-2015, 10:27 PM   #20
I've had a master for 20 years
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
hitch
