Old 11-20-2018, 08:49 AM   #121
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
They are out there, but the excursion came as a dually Diesel on the 350 chassis. Rare, but out there.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 11-20-2018, 08:58 AM   #122
Recently new!
Paulie1138's Avatar
One of the options on the old Excursions came on the 350 chassis as a dually with the 410 gears. Tow Monster! Friend had one, HATED to park it at any store! His duals were wider than most white lines in the spaces! Rare, but they are out there. Turning radius of a barge! Another option, get the cut-away 450 or 550 short bus chassis conversions. Those can be had used with low mileage quite reasonably, and can be set up to tow. May have to get a frame shop involved, but some come already equipped to tow.
2001 Ford F-250 7.3
Old 11-20-2018, 09:05 AM   #123
RV There Yet?
IsleDog's Avatar
This should work. It has negative hitch weight, lifts the rear of the TV a little (lot?) so you have EXTRA capacity for people and gear.
IsleDog is offline   Reply With Quote
Old 11-20-2018, 10:22 AM   #124
You are going to want at least a 10% buffer on your GVWR. I like a little more. Remember to calculate all people and luggage in addition to assuming the fluid tanks will be partial if not completely full. (just in case)
We had a old Dodge van, 2 captains chairs and 2 bench seats with plenty of room to lie down in the back.
I know some people use them for carpooling to offset the costs.
pohlcat01 is offline   Reply With Quote
Old 11-22-2018, 12:50 PM   #125
Best Vehicle for Towing
How about the Ford Excursion with the diesel option? It seats 8 and may have the towing capacity you need. Good luck!
440scout is offline   Reply With Quote
Old 11-22-2018, 01:32 PM   #126
Excursion and 2500 Suburban have the exact same GVWR the difference is the Suburban itself weighs at least 1000 pounds less giving at least 1000 pounds more payload. Sort of like why the new Ford pickups are aluminum, it frees up otherwise limited payload. 8.1 Suburban with 4.10 gearing is the only vehicle ever made that will do exactly what the OP asked.
Hersbird is offline   Reply With Quote
Old 02-23-2019, 11:45 AM   #127
The diesel Excursion on the 350 chassis is the best solution. Not only can it seat 8 people but with that Power Stroke diesel it will run circles around that Cheby Suburban!
Old 02-25-2019, 10:03 AM   #128
Buy a used 1 ton crew cab gasser. Use it only when towing. Take the money you save from the used vehicle, and buy a daily driver. When you go camping, load up the truck, and put the extra people in the daily driver.
2019 Rockwood Mini Lite 2509S
2018 F-150 XLT FX4 Crew Cab 3.5EB 3.55
Equal-i-zer E4 hitch 1,000lb bars
pilotpip is offline   Reply With Quote
towing
