Old 04-13-2016, 07:02 AM   #1
Better up or down?
I have to reset the hitch for the new TV. best guess right now, there is about a 1" difference between the TT tongue 19.5" and the Upper receiver of 20.5". My question when things are where they are supposed to be is it better for the TT tongue to be higher or lower?
c3prret is offline   Reply With Quote
Old 04-13-2016, 07:46 AM   #2
Lower. Level is optimal, but a slight tilt down of the nose of the TT is better than higher.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 04-13-2016, 07:57 AM   #3
jeff64's Avatar
Don't guess, measure! The TT is supposed to ride level. Consult the WDH manual and redo the setup steps. Measure! IF, I had to make that choice, I'd go nose down a tad. The adjustment on the bars or chains will affect level, steering and braking so, measure! Irregardless, if you buy a different TV or TT you will " reevaluate the WDH size and setup" 2 TTs ago I had a 6K Equalizer on a hybrid and a F150, now I'm running a 14K Equalizer on a 2500HD
Picture this... when you go into a gas station from the road, back into many sites or tag the brakes when you are on the highway what's going on with the TT due to changes in terrain or inertia?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 04-13-2016, 08:28 AM   #4
SeaDog's Avatar
The manual for my WDH says measure to the top of the coupler with the trailer level. Position your ball on the hitch so that it is 1" higher then the coupler on level ground. This is for my unit and may not apply to yours but gives you some info
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 04-13-2016, 12:47 PM   #5
Left Coast
Then load the bars till level?
Old 04-14-2016, 04:18 AM   #6
Thanks for the help. I couldn't remember which was best. Just using static numbers between the TT, TV and the shank adjustability right now.
Old 05-29-2016, 10:54 AM   #7
Finally had decent day to set hitch.
TT Roo 21 4700 max
Hitch Blue Ox sway pro 750 bars
2010 expedition Limited EL 4x4
unhitched front 36" rear 35"
hitched front 36" rear 34.5
Trailed when hitched Level
I tried both 8 and 9 links, no change
Am I missing something? Maybe shocks need to be replaced?
Old 05-29-2016, 01:27 PM   #8
Looks perfect. What is your perceived problem?
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
lbrjet is online now   Reply With Quote
Old 05-29-2016, 02:16 PM   #9
No real problem, just seemed strange the front stays the same no matter what, and the back drops. Thought possibly the shocks were bad.
Old 05-29-2016, 04:40 PM   #10
Shock absorbers don't carry any weight, they simply dampen movement.
k5rcd is offline   Reply With Quote
