Old 01-28-2013, 06:52 AM   #31
ebemis's Avatar
Hey James.....how do i say it?......I feel your pain!!!
First off, thanks for the follow through and encouragement, I kind of figure that I am EXACTLY where you suggest...what I have I have currenlty, and I refuse to sink any funds into trying to improve something that is brand new. Should my TV not be happy with the TT I have selected my plan is just what you suggest, ditch one or the other and try something different! :-)
Second...YES I too am frustrated by the apparent lack of concern to build ANYTHING anymore with quality and durable pieces and parts. Nothing frustrates me more than spending so much money on a brand new vehcile or item only to find cheap plastic and whimpy parts that don't seem to last worth a darn!!!
I camped with my family as a kid growing up for years...78' Chevy panel van dragging around Coachmen's and Prowler's up to 24 feet from what i remember...never had any issues then. Have been tent camping with my wife and kids now for years watching all the RV folks come and go and dreaming of being able to trailer camp again. I truly hope that I end up pleasantly surprised and find that my current TV/TT combination "behaves" itself around "flat Florida" with occassional North Georgia and Western NC runs.
Thanks again for the information and sharing, I truly appreciate learning from everyone else's experiences!
Ed
Ed & Chris
Josh & Jaclyn
2012 Suburban LTZ
2013 Rockwood Roo 233S
ebemis is offline   Reply With Quote
Old 01-28-2013, 07:25 AM   #32
FYI, If you haven't you might want to do the math. Just a suggestion
Tow Vehicle Sizing
grayfox is offline   Reply With Quote
Old 01-28-2013, 07:28 AM   #33
Ed,
You are very welcome for any experience I can share with you.
Like you, my Dad drug around a camper behind... get this... a 1971 Oldsmobile Delta Custom car! Of course it had the big 454 motor, but still... it seemed like back then you could hook up just about anything behind vehicle made and tow it.
I am pretty sure your saving grace will be GM's new 6-speed tranny. Having the extra 2 gears worth of "grunt" would have been nice on my 2004... add the 4:10 gears and I would have probably been okay for this part of the country.
We go out west to Colorado and Utah every couple of years to camp though... and there was absolutely NO WAY I was taking the Burb out there. When you have 6 and 7 percent grade for 20 miles stretches at a time... just no.
Please report back and give us a "true-boots-on-the-ground" assessment of your experiences with the newer model 1500 Burb. Also, after visiting a CAT scale, let us know your actual weights. I am genuinely interested in knowing if GM did it right this time.
Take care,
James
2005 Excursion Limited dragging a 2012 Roo 233s
DSN46 is offline   Reply With Quote
Old 01-28-2013, 07:47 AM   #34
prof_fate's Avatar
Originally Posted by ebemis View Post
VERY interesting reads......and now that I THOUGHT I did a good thing trading in my 2005 Burb with 180K miles on it for a spiffy new 2012 Burb (yes the 1/2 ton) I read all of the postings here and now have doubts.
I will be towing a new Roo 233S which isn't really rated to be that heavy (GVWR @ 5764) and my new Burb has the Integrated Brake Controller with a 5.3L V-8, 6 speed electronic HD AT, HD Trailering Package with the 3.42 rear end and External Air-Oil and Air-Trans Coolers. By GM specs tow rating is 8100 lbs so I "believe" that I am WELL underneath that.
Granted I haven't taken ownership of my new Roo to tow it around yet, but I sure hope that I don't end up finding out a 3/4 ton purchase would have made more sense :-(
I think yoiu should be fine - but close. You say the GVWR of the trailer is 5700 - on the door will be a sticker telling you what the factory weight is complete with options. Add 150 for gas bottles and batter, another 100 for the WD hitch stuff, add up yourself, your family, dog, etc that go in the truck. I'm thinking you'll have a weight of 5500ish. Now you have to try and guesstimate (or load and go weigh) what you'll have for bath stuff, chairs/tables/mats/light, dishes, food, bedding, clothing (1000lbs? others here may may have an idea what is 'normal' for trailer cargo). THis assumes you have no water/waste in the TT of course. so now you're at 6500ish. Water can add 300-500lbs to that.
So if you figure 7,000 lbs for trailer and cargo in the 'burb, what is the weight of the burb and what is the GCWR of the burb (these should be on the sticker on the door frame).
YOu can't do much to realistically raise your capacity - 2500 trucks (they tell me) have heavier frames, transmissions, bigger/better cooling, bigger brakes, heavier axles, springs, etc.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 01-28-2013, 08:03 AM   #35
MtnGuy's Avatar
Before buying that new Roo, take your Burb to some scales (local landfill, quarry, or CAT scales) with the family (including pets) loaded up a full tank of gas, and all expected additional cargo (camping gear, personal gear, luggage, etc) to see what it weighs. Subtract that figure from the GVWR listed on the driver's door. If any weight is left, than that is what your maximum trailer tongue weight is gonna be before reaching your GVWR. For that particular Roo, you might have as much as a 600 lb. tongue weight when loaded.
Also, find out the GCWR of the Burb. The listed 8100 lb. maximum towing weight is usually determined with an empty vehicle with just a 150 lb. driver. If the Burb is near the GVWR, then the 8100 lb. towing weight is going to drop significantly.
Old 01-28-2013, 09:49 AM   #36
ebemis's Avatar
Excellent responses from ALL of you, thanks once again!
Unfortunately all of the “purchasing” has already been done and all I am waiting on is the actual “take possession” step of our Roo purchase which is this Thursday. We don’t plan on boon-docking so I have no plans to pull water around, leaving me only to struggle with the cargo and person load. I don’t anticipate loading too much into the Burb other than maybe food and clothes, our thoughts were everything else would be inside the TT itself.
By the sticker on my TV door, my GVWR is 7200 # and the GAWR RR is 4200 # and according to my owner’s manual (1500 Series 2WD Long Wheel Base w/ K5L HD Cooling Pkg) the GCWR is reported as being 14,000 #. I need to get to my TT to see the sticker on its door, but according to the manufacturer’s brochure, the GVWR on the TT is 5764 #, which yes I am taking with a grain of salt. We will be using the Equalizer WDH System so I know correct packing and setup can zero the tongue weight in where it needs to be.
SO despite all of the “on paper figures from my stickers and manuals” YES I AM VERY MUCH looking forward to hitting the scales and finding out just where things end up! I will post back once that happens and after a few drives to let you all know how things worked out.
Ed & Chris
Josh & Jaclyn
2012 Suburban LTZ
Old 01-28-2013, 10:56 AM   #37
Boots49's Avatar
Send a message via Skype™ to Boots49
It is not only the weight you have to consider, but also how far you are going, when we left Montreal, Quebec for Calgary, our 3/4 ton GM, Minna was her name, did not even feel the weight. I have to go back to work, the wife is calling.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 01-28-2013, 12:18 PM   #38
ebemis's Avatar
yup that makes sense too Al! I'm not real worried as a Florida flatlander, I don't see myself making it out west for mountains, and we really don't pack heavy so im thinking i should be alright.....BUT I am interested in getting actual weights in on everything that is for sure!
Ed & Chris
Josh & Jaclyn
2012 Suburban LTZ
Old 01-28-2013, 01:41 PM   #39
trudinator's Avatar
DSN46 - we could have been in your situation. We have an '02 Durango. Yeah, the smaller one before they made them a bit bigger. We'd been dreaming of a TT for years and in 2011, finally made the decision to buy one. The practical side of me wondered how we'd pull this thing and my DH assured me that the Durango WOULD pull it. I was a nervous wreck from the moment we put the deposit down, wondering how we'd get this thing home, let alone pull it fully loaded. It was karma.....5 days before we were to pick it up (not knowing that it would only be 5 days), my DH walked into the Dodge garage for something unrelated, and there it was....the truck we were "building" in our minds. They were taking photos of it to put up on their website. Gently used Dodge, extended cab, 8-foot bed, diesel, running boards, 50K miles, etc., etc., etc. We crunched the numbers...could we afford it....it will be a hardship for a while...can we get two loans at the same time? We couldn't afford NOT to get this truck. We picked it up at 5pm on Friday and by noon on Saturday we were leaving the lot with our brand new TT. And I was sooooooo relieved. This truck pulls our TT effortlessly and I don't have to worry about us killing ourselves or someone else because the Durango can't handle the load. So here's my advice to everyone....get the TV first, then get the TT. Your lives depend on it.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 01-28-2013, 02:20 PM   #40
prof_fate's Avatar
GVWR is gross vehicle - how much it can weight LOADED to the max.
What you also need is the ACTUAL WEIGHT of the vehicle. THis sticker should be on the inside of the screen door on your TT and may be on your truck's door.
We're not big on campfire but I see some folks draggin 1/2 cord of wood along. We do bring bikes though - 20-30lb per bike times 4 bikes is another 100ish lbs.
While you may not fill your tanks you will have some fluids in there - nobody that I know drains completely before moving, so 6gal in the water heater, 3 more in the pipes, some in the toilet bowl - and as my neighbor advised keep 10 in the fresh tank for emergency (radiator, potty breaks, etc) and most black tanks want some water in them with a chem so you don't get odors. So what, 20 gallons? 160 lbs.
A case of beverages weights something - I've switched to canned beer as it's lighter than bottles and easier to pack in the fridge. My wife has coke. my son sprite and then a case of water bottles...4 cases of drinks is around 80lbs.
Get a memory foam mattress topper (for the camper and home - they're great) but add another 20 some lbs.
Leveling wood, wheel chocks, better sewer hose, vent covers, water filter, longer ele cord and adapters...
It adds up.
2011 Grey Wolf 28BH
