Old 07-20-2019, 07:28 PM   #1
Bike rack and towing with one hitch?
We bought this Yakima bike rack but now we may also want to tow a Bug behind our FR3. Is there any way to somehow attach both to one hitch at the back of our RV? TIA!
borismkogan is offline   Reply With Quote
Old 07-20-2019, 07:32 PM   #2
Capt. Mike's Avatar
Yes. You can get a dual-receiver hitch extender. Hook up the tow bar to the Bug in the bottom receiver, and the bike rack in the top receiver. Check that your tow bar is long enough that the bikes won't hit the front of the car on turns. Here's a link to one available from etrailer.
https://www.etrailer.com/Hitch-Adapt...iABEgL5vfD_BwE
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
It's not how old you are, it's how you are old.Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 07-20-2019, 08:10 PM   #3
DaGrinch's Avatar
And here's one from Harbor Freight....
https://www.harborfreight.com/search...ceiver%20hitch
Just make sure any dual hitch will be heavy enough for what you want to haul/carry.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 07-20-2019, 09:04 PM   #4
Measure and template with cardboard first. The dual receive adapters vary in space between the upper and lower.
In my case, we use one to Dolly tow as well as a cargo basket (with 150 lbs load}. The cargo basket is has an offset bar which raises it enough to clear the dolly.
Depending on your needs, you can get a dual receiver with a long hitch adapter for clearance, or a hitch with a second receiver on top.
2016 SS 2250 E450
Dp26 is offline   Reply With Quote
Old 07-20-2019, 09:08 PM   #5
Image. The distance is deceiving. There is several inches clearance between the carrier and the car bumper. The carrier clears the dolly by about 6 inches at the ball and has plenty of clearance for the road
Old 07-20-2019, 09:23 PM   #6
Perfect! Thanks a ton!
Old 07-21-2019, 06:29 AM   #7
Thank you all! Very helpful!
Old 07-21-2019, 01:52 PM   #8
hitch
Why not put a hitch receiver on the bug and mount the bikes there??
SeaMSea is offline   Reply With Quote
Old 07-21-2019, 03:35 PM   #9
Here is my setup
Drop down receiver has the bike rack reveiver welded on top. See attached photos
ID:	210455   Click image for larger version
JimRynd is offline   Reply With Quote
bike, bike rack, hitch, towing
