Old 12-19-2015, 10:30 AM   #11
mach8274's Avatar
I am installing Bilstein's on my truck next month. i am going with the 5100's. My truck is not lifted. The different variants on the 5100's I believe are for different lift heights. Just go with the 0-2" and they will work just fine.
Dave & Amy
5 kids, 2 with 2 legs, 3 with 4 legs
2016 Columbus 385BH "No Worries II"
2016 F350 6.7L PSD CC Lariat DRW "Mistress II"
Ford factory puck system with 26.5k hitch
mach8274 is offline   Reply With Quote
Old 12-19-2015, 10:34 AM   #12
Nomad, for your truck the part numbers are - 25-196474 for the front, part number 25-196481 for the rear, these are 5160 series shocks for a 0 to 1.5" lift. You will want to double check with your preferred supplier for the correct part numbers before you purchase.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-19-2015, 10:43 AM   #13
nomad297's Avatar
Originally Posted by lbrjet View Post
When I got my 4600's last year there was only one front set and one rear set that fit my truck.
Yes, the 4600 is an easy choice -- there's only one that will work. However, there are a ton of choices in the 5600s.
Bruce
Old 12-19-2015, 10:52 AM   #14
Nomad if you just want a OEM replacement Bilstein heavy duty shock, the part numbers are
24-196444 for the rear
24-196437 for the front
like I said before double check with your supplier.
If you want a 5100 series numbers are
24-196451 for the front
24-196468 for the rear
these are for a 0-1.5" lift
2014 Forester 3051s
2012 Sonic toad
Old 12-19-2015, 11:35 AM   #15
CWSWine's Avatar
I called the shop that installed mine and that main focus is lifted trucks and this what he explained to me.
That the 4600 and 5100 have the same specs but the 4600 is made for trucks with zero lift. The base 5100 is made for truck with a lift kit. The way the shocks works is when the shock is in center travel it moves either way from center the resistance increases the father away from center the shocks moves. On a stock truck the 5100 shock would not be at center travel and the 5100 would be a compromise to allow for a 0 to 2-inch lift but will work fine and nothing wrong with using them. He also said that by the seat of pants you probably won’t be able to tell the difference except if you get the 5100 you wallet will be a little thinner and easier to sit on.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 12-19-2015, 04:08 PM   #16
panthercity's Avatar
I put the 5100s on my non lifted C2500 and love `em! Look for the 0 to 2" lift (or something like that).
Certified JB Welder. Certified 3M Duct Tape installer.
Certified Farmer's Co-Op bailing wire expert. Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
Getting old is just a matter of narrowly missing all the things that kill you.
panthercity is offline   Reply With Quote
Old 12-19-2015, 04:23 PM   #17
Originally Posted by nomad297 View Post
So often I read here where people have replaced their OEM truck shocks with Bilstein shocks. However, I haven't noticed any references to which particular Bilstein shocks they used -- which series or model number. I am interested to know which Bilstein shocks everybody has used.
Which Bilstein shocks would be best for my 2015 Cheverolet Silverado 3500HD crew cab with 6.0, 4x4 and 8' bed with no lift? Is this enough information, or do I need to be more purpose-specific?
Bruce
Bilstein has a database that will direct you to the correct shock for your vehicle. Go to a vendor in person, or on the net and input your vehicle specific information.
Old 12-21-2015, 06:46 AM   #18
mach8274's Avatar
On Amazon, the 5100's and 4600's are within a dollar or 2 of each other...well, for the ones I need. Don't know about the others.
Dave & Amy
