Old 12-19-2015, 09:01 AM   #1
nomad297's Avatar
Bilstein Shocks
So often I read here where people have replaced their OEM truck shocks with Bilstein shocks. However, I haven't noticed any references to which particular Bilstein shocks they used -- which series or model number. I am interested to know which Bilstein shocks everybody has used.
Which Bilstein shocks would be best for my 2015 Cheverolet Silverado 3500HD crew cab with 6.0, 4x4 and 8' bed with no lift? Is this enough information, or do I need to be more purpose-specific?
Bruce
Old 12-19-2015, 09:19 AM   #2
ddphillips52's Avatar
Bilstein 5100's have always worked well for me.
Dennis, Linda, and Scout the Dog
2015 Mesa Ridge 347 RES
Husky 16KW with Reese Sidewinder
2013 4WD RAM 3500 Cummins TD SBCC
ddphillips52 is offline   Reply With Quote
Old 12-19-2015, 09:28 AM   #3
nomad297's Avatar
Which 5100s?
Bruce
Old 12-19-2015, 09:35 AM   #4
muddyrode's Avatar
I went with the 5100 also they work good for me, also but i did put air bags on the back just to frim up the back from a little body roll i would get in a good cross wind i just run 15.PSI in them and that keeps it off the overloads and helps a lot i have about 1900 lb in pin weight. i bought mine through e shocks they were about the best price i found
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 12-19-2015, 09:40 AM   #5
CWSWine's Avatar
I put on the 4100 series on my F350. I ask for 5100 but after the tech looked them up he said they were designed for trucks with a lift kit and the 4100 are without lift. I have read that people have put them on non lifted trucks.
This is from Blistein website....
BILSTEIN 5100 Series Shock Absorbers are designed specifically to help your lifted truck, Jeep or SUV reach its pinnacle in ride performance, while supplying the correct tuning and length for your specific lift.
http://www.bilsteinus.com/products/t...ight-trucksuv/
Edited - That should read 4600 series not 4100 series.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 12-19-2015, 09:45 AM   #6
nomad297's Avatar
5100 Series - Lifted Light Truck/SUV
Do you mean the 4600 Series?
Bruce
Old 12-19-2015, 09:46 AM   #7
CWSWine's Avatar
Bruce
You are right 4600 series.
Old 12-19-2015, 10:08 AM   #8
I use the 5100 shocks. They make a noticeable improvement in ride and handling.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 12-19-2015, 10:10 AM   #9
nomad297's Avatar
Do you use these in replacement of the stock shocks with a non-lifted truck? Which 5100s do you use. There are so many variants.
Bruce
Old 12-19-2015, 10:25 AM   #10
When I got my 4600's last year there was only one front set and one rear set that fit my truck.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
